83 308 qv alternator belt part #? | FerrariChat
Discussion in 'Technical Q&A' started by dj393, Oct 12, 2010.
  1. dj393
    dj393 Rookie
    Mar 22, 2006
    38
    Tulsa, OK
    Don Jameson
    Anybody have a part number for an 83 308qv alternator belt? (has individual belt for alternator not combined with waterpump) Does anyone know of a good replacement belt that's not OEM? my belt decided to disentigrate the other evening and I would like to get it replaced pretty quick, but not sure which belt I can use.
  2. tatcat
    tatcat F1 World Champ
    Sep 3, 2001
    11,013
    panama city beach FL
    rick c
    go to the 308/328 forum. there is a thread with all the part numbers.
  3. dj393
    dj393 Rookie
    Mar 22, 2006
    38
    Tulsa, OK
    Don Jameson
    Thanks! I'll see if I can find it there.
  4. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,856
    NoNJ/Jupiter FL
    Steve W.
    Just a couple of quick thoughts here. Since the alternator belt went, you might want to check the water pump belt and replace that too. Belts are cheap. Since the alternator belt is the outside belt, you would have to remove it later to change or replace the water pump belt. And assuming they were of the same vintage, probably just as well to change that one too.
    When you install the new belt, make sure that both the tensioner bolt and the bolt holding the alternator to the bracket on the block are properly tightened. If the bolt on the block bracket is not tight, the alternator can work loose on the tensioner alone over time and cause the belt to slip, leading to failure. Ask me how I learned that one.
  5. 4rebob
    4rebob Karting
    Nov 3, 2003
    176
    Richland wa
    Robert Taylor
    I use Gates Polyflex on my 83 Mondial QV.
    AC - 11M925
    Alternator - 7M750
    Water pump - 7M630
    Smog pump - 7M500
    Part info from the Gates website:
    Product Number / Part Number / Description
    89030500 / 7M500 / 7M500 POLYFLEX
    89030630 / 7M630 / 7M630 POLYFLEX
    89030750 / 7M750 / 7M750 POLYFLEX
    89040925 / 11M925 / 11M925 POLYFLEX
  6. 4redude
    4redude Formula Junior
    Jan 13, 2005
    733
    Fungus Corner
    Brian Keegan
    I agree with FasterisBetter on this. WHY did the belt expire? Either the water pump packed up or the two bearings pressed back-to-back into the idler pulley did. If you need those bearings they are commonly available 6002-2RS (15x32x9 single-row ball bearings)
