83 308qv speedometer | FerrariChat
Discussion in '308/328' started by gr8hunter, Nov 24, 2013.
  1. gr8hunter
    gr8hunter Rookie
    Nov 20, 2011
    2
    This place has been a lifesaver to enjoying my car. I just want to pass along one thing I learned so that it may help someone else. I was having issues with intermittent speedometer readings. It seemed to work every time cold until after running a while then it would just drop dead.
    1) I changed the sensor.
    2) Cleaned the connections on the back of the gauge.
    Still had the same problem.
    3) Cleaned all wire connections at the battery terminal.
    Problem solved.
  2. bentrm
    bentrm Formula Junior
    Sep 17, 2011
    596
    Pittsburgh, PA
    Rob
    Thanks for posting! Prolly won't get many replies. But it's on here! Might help someone who uses the search. I love it. Why not help?
    Now, pic of your 83? I have the same.
  3. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    560
    London
    Anthony Bentley
    Mines exactly the same, same year car to, it reads then flops about then reads. I'm going to pull it soon and send it to speedy cables.
  4. doxviper
    doxviper Rookie
    Aug 14, 2011
    7
    Colorado
    Bill Schreiber
    How do you know it's not the sensor/transducer?
  5. doxviper
    doxviper Rookie
    Aug 14, 2011
    7
    Colorado
    Bill Schreiber
    Do you still have an extra sensor?
  6. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    I changed it. But binned it. One of my indicator diodes also has packed up so I'm going to try and pull the speedo and send it off.
