How does one disconnect this from the rear wheel hub? I don't see any brackets to unscrew, etc. Thanks
This help any?? Bigger version, copy/paste into your browser: http://www.eurospares.co.uk/userImages/036/Large/036_027.gif It will enlarge to full size if you click on the expansion icon in the corner. Looks like the cable-end is hooked onto the lever (#38) by tension when the adustments are done at the common mount (#22). Housing Stop (#25) is held into the hub by the same tension, should pull out one the Cable End is loose, doesn't show any threading. Image Unavailable, Please Login
Thanks Kurt. I got it out.........not too bad. I did the following: 1) Loosen the emergency brake inside the car 2) Removed the two brake lines, at the frame mount 3) Removed the long bolt holding the upper A-arm, and loosend the nuts holding the lower A-arm. This allowed the axle hub to pivot downward to a horizontal position.......with cable still attached 4) Removed plate beneath the center of the car, to expose the proximal end of the cable. Here I removed a cotter pin and moved the pivot pin (#18) upward, to get the cable wheel (#17) off. This loosened the cable. 5) With the hub in the horizontal position, I used a screwdriver to pry the cap(#25) away from the hub. I was able to keep pushing it away until I exposed about 6 inches of the cable. This allowed me to see inside (hub horizontal) and disconnect the cable. I plan on removing the hub, calipers and giving it a thourough inspection.
