'83 GTS: How much rust is "normal/average"? | FerrariChat
Discussion in '308/328' started by Imperial Stormtrooper, Feb 19, 2015.
  1. Imperial Stormtrooper
    May 7, 2014
    148
    Far, Far Away
    George
    Hey guys,
    I have a refundable deposit on an '83 GTS, and the seller disclosed the following when it came to rust:
    "There are three (3) areas that I am aware of that have or had evidence of rust in prior and current inspections;
    *The first is on the underside off the engine compartment lid and is visible in the most recent (interior) pictures of the engine area I sent to you. (FYI-I couldn't see it)
    *Second (and this has been largely resolved) was in the area of the rear valance. When the PO purchased the car, the paint on the louvered part of the valance had failed and the exposed metal had begun to rust. Accordingly, the valance was removed- to prepare (sand blast) for new paint. After removing, it was discovered that the valance had two (2) parts attached to it (heat shields for the rear bumper mounts). These parts were riveted to the valance and at that time,rusted. PO fabricated replacement parts, painted all, re-assembled the valance and remounted on the car. Note: According to PO's records, this valance was a used OEM replacement for the original in 1993.
    *The third area of possible rust is the bottom 2" of lower door panel on the passenger side door. This area is curious, as although it appears to be blistered, the paint seems solid and intact (not flaking) and the underlying steel seems firm. Our shop brought this to PO's attention some time ago and provided him with a name of our paint & body specialist and phone number to repair this, but to the best of our knowledge, PO never got around to pursuing it.
    *There are 2-3 dozen small stone chips currently on the front of the car, consistent with a 34k vehicle. Otherwise, I would say that the paint is in very good to excellent condition."
    This is a fully sorted/fresh service 2 owner car with an extensive service history at a reputable shop and a sub $50K price. I'm wondering what your thoughts are on the rust?
    Thanks!
  2. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I would be concerned with the rust under the bottom of the doors. This seems to be a prone area and if not taken care of it will eventually affect the door skin. A bubble usually means rust from the inside out.
  3. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,601
    Avvocato
    Rust is like cancer , the visable rust isn't the real issue, it's what else is lurking that could be the concern. I agree with the Steve king rust at the bottom of the door is a concern. Are you planning on redoing the car ? If you keep it, might not be a bad idea to think about it.
  4. greyboxer
    greyboxer F1 World Champ
    Dec 8, 2004
    12,695
    South East
    Jimmie
    Older Ferraris rust and its a constant vigil to keep repairing faults - it may be 5-10 years between issues - it may be less - but rest assured they are coming
    The areas described seem completely normal and if you don't want the car I'd be tempted to bring it to England
    As Steve says the door is a 'prone area' so quite why that should make it 'a concern' is unclear - just fix it
  5. Harry-SZ
    Harry-SZ F1 Rookie
    If it is a blister, it can still be fixed usually.
    If you wait too long, it can get worse.
    These are old italian cars, they can rust. Just don't wait too long to get it fixed and it is not a big problem.
  6. vaccarella
    vaccarella Formula 3
    Apr 16, 2011
    2,291
    Paul
    Show me a 1980s car without rust. It isn't a matter of being a Ferrari or of being Italian. It's chemistry and time. Just fix it.
  7. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,607
    Gates Mills, Ohio
    Jon
    I agree. This is common on 308s, but not "normal".
    The description of the car suggests it may have lived in a wet environment. I would look it over carefully.
    Rustproofing started in January 1984, which isn't a guarantee of anything but in my experience seems to improve the odds of finding a car with clean doors.
  8. 308 milano
    308 milano F1 Veteran
    5,342
    Montana
    Kim
    #8 308 milano, Feb 19, 2015
  9. 308 milano
    5,342
    Montana
    Kim
    #9 308 milano, Feb 19, 2015
  10. 308 milano
    5,342
    Montana
    Kim
    #10 308 milano, Feb 19, 2015
  11. Bones2U
    Bones2U Formula Junior
    Jul 13, 2008
    814
    Ontario
    You can buy a car without these issues for a bit more money. That's what I would do...LOL.
    M.
  12. 308 milano
    5,342
    Montana
    Kim
    With my project car, I knew going into it what needed to be done, ( yes, mine also has lower door issues that I will be addressing shortly).I wanted a car that I could tinker with as my QV does not have any of these issues. Just Understand that you will probably spend $5000 addressing these issues. Like others have said it's an old Ferrari, kind of comes with the territory.
  13. Rich S
    Rich S Formula Junior
    Nov 30, 2013
    501
    Monterey, California
    Rich Saylor
    #13 Rich S, Feb 19, 2015
    No matter the preparation- primer, galvanizing, whatever- steel can eventually rust, depending on the conditions. California cars have a reputation for not rusting but it's not an entirely deserved one. Cars can rust here, too; just takes longer, mostly. We do not use salt on our roads (including the mountains (as so many winter-prone areas do, here & abroad). So: rust appearing anywhere on a car is a sign that either there wasn't enough rust protection to begin with, or too much exposure to weather (especially salt) or both. As they say, "rust never sleeps". Personally I'd look around for a later car, one with the galvanizing Ferrari eventually used....right around '83 or so, yes? But is the one you're looking at pre- or post- galvanizing? As a previous poster said, most often rust comes from the inside out! That alone makes getting rid of rust in a welded body a difficult proposition...and an expensive one! Too bad the earlier fiberglass body cars are now so expensive...!
    Buying a car with known areas with rust is really buying a pig in a poke. Even a normal repaint is pretty expensive, done right (stripping everything including rubber & glass,etc.) but taking a car down to metal- inside & out, or else you're wasting your time- is REALLY expensive. Maybe not for a $500,000 car but for sure for a $50.000 car!
    Or as the ancient knight in the Indiana Jones flick said, "choose wisely..."
    Cheers,
    Rich
  14. 308nut
    308nut Formula 3
    Jul 22, 2002
    1,881
    NOLA/Covington
    Wade
    What is the VIN, i recently looked at an 83 for a client that had major rust issues hidden behind moderate rust issues. I have done lots of cars with rust and what is on the surface is typically followed by lots more inside, just remember this once you start cutting it out there is no turning back.
    Wade
  15. Albert-LP
    Albert-LP F1 Veteran
    8,182
    around Modena, Italy
    Alberto Mantovani
    my 83 hasn't visible rust anywhere. An 85 QV i wanted to buy had a lot of rust. Rust on the lower part of the doors is quite common. Rust on the lower rear panels, rockers and around the windshield base is frequent, but not so common: means the car did a lof of miles or wasn't well cared. In any case you can fix it. Often the lower part of the doors is cut away and replaced with zync plated iron sheet.
    Rust not only on the lower part of the doors means a USD 6-12 K work to do on the car body.
    Pay attention: with rust I mean many small paint bubbles. If you directly see the brown rust, maybe it's better looking for another car
    ciao
  16. Harry-SZ
    Harry-SZ F1 Rookie
    They got a zincrox treatment (from buildyear 1984) that was a bit better than no treatment, but still not up to modern standards. So later 308's and 328's can have rust also.
  17. Ladybegood
    Ladybegood Karting
    Feb 17, 2012
    192
    Derbyshire, GB
    My 84 has been in UK all her life, so wet wet wet. The rear valance near the bumper was rusted through and had to be cut out and replaced, all the wheel arches, and bottom of doors had been replaced but need doing again. Round the front lip over the grill needed repair and at the side window. But hey 30 year old car and daily use and she still drives beautifully
  18. brian.s
    brian.s F1 Rookie
    Nov 3, 2003
    3,809
    Midwest
    Brian
    Most definitely! What you see is just the tip of the iceberg.
  19. andyww
    andyww F1 Rookie
    Feb 7, 2011
    2,775
    London
    Rust along the bottom of the doors is normal. Rain or water from washing runs down the windows into the doors and stays in the bottom of the doors. Although there are drain holes they are pretty useless as they are above the lower part of the door, where the outer skin folds around the door frame. There is a V shaped channel formed by the skin and frame which holds water and this soaks into the joint between these two parts and simply stays there doing its evil work.
