83 QV air pump | FerrariChat
83 QV air pump
Discussion in '308/328' started by matteo, Jan 22, 2006.
  1. matteo
    matteo F1 World Champ
    Aug 1, 2002
    13,748
    On a plane somewhere
    Heir Butt
    Last week my air pump was running meaning that it was spinning. Today, I took a gander and it's not spinning while the motor is running.
    I recall a conversation I had a few weeks ago with a Ferrari mech at Auto Gallery that there is a piece on the end of the cam shaft that breaks when the pump siezes. Could the have broken?
  2. Dr Tommy Cosgrove
    36,447
    Birmingham, AL
    Tommy
    Do you want it to work?
  3. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    #3 matteo, Jan 22, 2006
    Not really :) but I live in Ca so I have too
    I was just working on the car.
    I took the belt off the airpump as a "just in case"
    After I did that, I noticed that the pully was rotating and then upon futher inspection, I noticed that there was a pin that was hanging off the pully. I stopped the motor and pushed the pin back in and then it started rotating again. It seems that this pin worked it's wasy loose causing the airpump belt to stop spinning.
    Part #66 and #45 shown on the pic.
    What's the deal with this?
  4. Dr Tommy Cosgrove
    36,447
    Birmingham, AL
    Tommy
    How do those things work? Do they just dilute the exhaust gases?
  5. matteo
    Aug 1, 2002
    13,748
    Heir Butt
    dunno.
    It's expensive to fix though.
  6. Dr Tommy Cosgrove
    36,447
    Birmingham, AL
    Tommy
    If that's all it does, how does that help anything? It still puts out the same amount of hydrocarbons, just less concentrated with each exhaust stroke. I am just guessing, though.
  7. lm2504me
    lm2504me Formula 3
    1,122
    Nipomo, CA
    Richard
    The air injected in the hot exhaust adds the additional oxygen to allow for the excess hydrocarbons to be burned up. This reduces the HC amount prior to the catalytic converter or thermal reactor on the earlier 308.
    Burning the leftover HC significantly increases the temperature of the exhaust.
    Richard
  8. Steve Magnusson
    26,838
    It's more than just adding volume to reduce the HC concentration -- the O2 in the added air chemically reacts with the unburned HC to form more CO2 and H20 (and actually reduces the total mass amount of HC coming out of the tailpipe).
    Without the added air, a catalytic converter will age/foul more quickly -- especially on a carbed set-up and to a somewhat lesser degree on a non-Lambda injected set-up like an '83 QV.
    In the warm-running, closed-loop mode on the later Lambda-equipped cars, they run so lean that they don't need the extra air, but during cold-running even those need the extra air added to keep the cat healthy and effective.
  9. Dr Tommy Cosgrove
    36,447
    Birmingham, AL
    Tommy
    That had to be a terrible way to do it back then. It seems obvious that an engine needs to be designed with emissions in mind to begin with instead of designing emission controls around an engine as an afterthought.
