Guys, I'm positively surprised with the LB. However, i couldn't find any technical details of this car on Ferrari website, does anybody have the details e.g. weight EU etc. ?
Dry curb weight is 3240 lbs. More details here: https://www.roadandtrack.com/news/a36820463/2022-ferrari-296-gtb/ Price is said to be $320k
amazing but i still bet real hp is just under 800. and real curb weight will be 3600 lbs. will there be dealer premium on it though? i dont think so since sf90 didnt
830 does sound crazy but only like 300hp is gas powered and the rest electric. Aren't all electric cars like Tesla really high hp?
Hard to tell online sarcasm or not these days, but to correct the above numbers: 654hp gas powered + 164hp from the electric motor totalling 818hp.
No worries, there's a good bit of 296GTB critics so I wasn't sure if I was correcting an intentional joke
I have to get more knowledgeable on these hybrid powertrains. After a quick look I thought ,oh no this car is like that goofy BMW I8 with the 3 cylinder motor and the hybrid assist. It actually seems more like a very slightly emasculated SF90. And I for one like the design here
Do we know that the extra electric HP is actually added at peak HP? Second hand info, but I heard the Artura's electric motor is more for engagement at lower rpm's when HP and torque of ICE motors is the lowest, then the engine takes over at higher RPM's -so you never really get the total HP claimed as it is distributed to level out HP/torque curve
People will throw it on the dyno to find out I guess! I don't see any reason the electric motor couldn't also assist at high RPM.
The ICE is making its peak power close to the top RPM, and the claimed power figure is 830HP so that means the electric motor power is added on top of the max power output from the ICE, ie close to max RPM. Also, electric motors have a almost flat torque curve (same torque at low or high RPM) and the power is torque X speed, so the peak power will be at the motor's top speed. So yes, adding the top power of both ICE and electric motor is a fair calculation of the power train max power.
Electric motors have full power output at zero RPM and then taper off. Many are of no use at higher RPM and are just used for torque fill-in at low RPM when you have a tiny engine that's tuned for power at high RPM. The norm for the hybrid is you never get both engine and motor outputs combined.
How does the sf90 make sense now. I get it’s an 8 but does this cannibalize sales of the 90? For the price of it I am happy to keep my GTS and a NA 12 and pick up a 296 as a stablemate. Curious if any current or soon to be owners of a 90 are surprised by the 296?
Low RPM always means low power, as power = torque X speed. I guess you meant "electric motors have full TORQUE at zero RPM and then taper off". Which is true. But as motor RPM increases, the generally reaches a max power number, then the continuous increase of RPM is compensated by the decrease in torque. Example below. Image Unavailable, Please Login So max electric power can be summed to max ICE power, providing the electric motor was indeed intended to help as well in the high RPM.
The same that makes naturally aspirated engines vanishing for non hybrid cars - with the current ICE technology a turbocharged engine is simply more efficient, with no objective disadvantage (except for noise lovers, because a naturally aspirated engine will typically rev faster).
