Glare reduction for 308 dash | FerrariChat
Discussion in 'Technical Q&A' started by chris marsh, Nov 20, 2005.
  1. chris marsh
    chris marsh F1 Veteran
    5,757
    Detroit
    Chris Marsh
    I once saw a guy who had a matte mat to cover his dash while driving eliminating glare. Anyone know where to get one? (I can bareley see when I drive into the sun)
  2. wise3
    wise3 Formula Junior
    Oct 10, 2004
    375
    FL
    Ward Orndoff
    I had one of these back in the 80's, but left it at a track meet (sigh). Got it from F.A.F., I think.
    There is one for sale on ebay at the moment; look under 308 dash cover. Like the one I had, the top surface looks like carpeting. Ad says it is new, so if it sells, you still might learn the source from the seller.
  3. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
  4. chris marsh
    5,757
    Detroit
    Chris Marsh
    they do not, I've tried Revo and OP. Thanks for the info I've ordered a mat.
  5. Jdubbya
    Jdubbya The $10 Trillion Man
    43,079
    PNW
  6. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    They do for me and several other folks on the board. But the mat does it for sure... I've got one of those too. You don't have to use the supplied velcro to keep it in place, though. What I do is remove the three round dash vents (the oblong ones don't come out easily) and then put them back in through the OUTSIDE of the dash mat vent holes. Holds it in place wonderfully.
  7. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Good tip Mike.
    I love my 308 dashmat!
    Greg
  8. 308 GTB
    308 GTB F1 World Champ
    11,713
    New Jersey
    Barry Wolinsky
    I keep a piece of black felt material in the car. I place it atop the instrument pod during sun glare conditions. It works well.
    Barry
  9. FourCam
    FourCam Formula Junior
    May 19, 2004
    409
    Loveland CO
    Cameron MacArthur
    Me too. I have had a cover for a couple of years and it works great. My only complaint is that it looks just a little tacky, but from a safety and eye-strain standpoint it makes alot of sense...
  10. parkerfe
    parkerfe F1 World Champ
    Sep 4, 2001
    12,887
    Cumming, Georgia
    Franklin E. Parker
    I use one in my Boxer and it works great. My fits great and stays in place without the velcro. It also protects the dash leather from the sun. ;)
  11. BigTex
    79,368
    Houston, Texas
    Bubba
    My 308 from Montana came with the instrument pod covered in mousehair.
    It's stitched to match the rest of the dash........works OK......
    The MAIN thing is to avoid swabbing a greasy Armorall treatment on the dash, in the first place! ;)
  12. chrismorse
    chrismorse Formula 3
    Feb 16, 2004
    2,150
    way north california
    chris morse
    I bought a dashmat but haven't velcrowed it because i was less than happy with the fit & thought it might lay out a bit better after a few weeks in the sun but it still fits poorly.
    Before i send it back for another try, i thught i'd ask how well others "mats" have fit.
    chris
  13. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    Chris,
    Funny you mentioned poor fit.
    The left part of my DashMat doesn't contour properly with the dash that's to the left of the instrument binnacle. I had to tuck a flap under, but it's close enough.
    I figured they're all cut to same, wrong template, so I didn't exchange it.
    The vent holes all line up nicely. All in all I'm satisfied..
    Greg
  14. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I *did* send mine back and got another one, and it had the identical issue. But as you say, it's "close enough".
  15. Gatorrari
    Gatorrari F1 World Champ
    16,449
    Georgia
    Jim Pernikoff
    I disagree, Mike; I have polarized sunglasses and still get a bad glare off the central raised binnacle that holds the speedo and the tach. (The rest of the dash is not a significant problem.)
    I may get a dashmat and just use the central portion.
  16. chris marsh
    5,757
    Detroit
    Chris Marsh
    I think we've got a terminology difference. I should have described my problem as reflection, not glare. It is the reflection of the instrument pod that causes my issue. Sunglasses seem to have no-effect on this reflection.
  17. chrismorse
    Feb 16, 2004
    2,150
    chris morse
    Maybe since i'm a bit shorter and fatter, i get a lot of dash glare reflected up onto the windshield from the whole dash.
    The dashmat really cuts down on the reflected light and since the fit seems to be fairly "standard", i will go ahead and velcrow it in.
    best,
    chris
  18. DKHudson
    DKHudson Formula Junior
    Sep 1, 2004
    438
    Durham, UK
    David Hudson
    Personally I use a £25 pair of Polorised sun-glasses and they work fine for sun, glare and reflections. However Poloroid does not work quite so well for overcast skies when the difuse light is not clearly polorised.
    Different sunglass manufacturers use all sorts of terminology, so a quick test for good poloroid... Take two pairs of the glasses to be tested and put one in front of the other so you are looking through both lenses. Then turn one of the glasses to 90 degrees and the view should blacken entirely. If there is no change in the tint level, they are not proper polorising filters. (You can also check against camera poloriod filters and LCD displays that rely on poloroid technology - say calculator display).
    My bug-bear is night time street lighting, I wound up re-shaping and altering the park position of my wipers (down the screen) as the combination of glare and wipers were hiding the kerbline at night. Not fun.
    David.
  19. chris marsh
    5,757
    Detroit
    Chris Marsh
  20. wildegroot
    wildegroot Formula 3
    Nov 19, 2003
    1,522
    Frenchtown NJ
    Wil de Groot
  21. Milkshaker0007
    Milkshaker0007 Formula Junior
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    Using this old thread I found for a little help please from over the pond.
    I'm suffering very badly in the UK when we do get the sun, it's very dangerous, I can hardly see at times due to the GLARE off the binnacle.none of my sun glasses totally eliminate it, so I need a cover of some sort.
    Has anyone got a picture of one of these dash covers on there 308/328 I can see in place, to get an idea what they look like before I order one.
    Ideally I would like to find a place in the UK or Europe to save on taxes.
  22. George Vosburgh
    George Vosburgh F1 Rookie
    I don't have a picture of a cover. They are very unattractive in my opinion but they do work. You can also just put a black towel down on the dash in front of you. I just learned to up with the glare. It's part of the charm of being "old school".
  23. Milkshaker0007
    Sep 22, 2012
    432
    Midlands,uk
    Paul
    Thanks for reply George,
    As above anyone got one on there car and can post a pic
    Cheers
  24. Crowndog
    Crowndog F1 Veteran
    Jul 16, 2011
    7,042
    Fairfield,Pa
    Robert
    I found having the binnacle recovered in leather made a very big improvement. I also have the Dash- mat for really bright conditions.
  25. moysiuan
    moysiuan F1 Rookie
    4,180
    Canada
    Makes you wonder why Ferrari ceased using the suede type of material on the older 60's and 70's car dash and instrument binnacles, other than on the 288GTO. Made most sense to avoid this glare issue in the first instance. If my leather ever cracks or shrinks I might redo in the vintage material, mind of like modern alcantera fabric.
    Milkshaker0007 likes this.
