84 308 engine shuts off while driving | FerrariChat
Discussion in 'Technical Q&A' started by PCosta, Jul 29, 2008.
  1. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    I drove the car for about 40 minutes and when I pulled off the freeway there was a loud back fire, then the engine stuts right off??!! The car did not re-start for about 30 minutes later, drove it home with no issues. I took it out this morning and again no issues. Any suggestion to what may have happened? Thank you.
  2. f308jack
    f308jack F1 Rookie
    Jun 7, 2007
    4,300
    Cape Town, South Afr
    Jack Verschuur
    My '82 suffered from sudden dead a few times just after I bought it. No dash lights, nothing. Couldn't find any faults, then stumbled across a battery that would short periodically. Stuck a new battery in and no problems for 10k kms.
  3. bannedleader
    bannedleader Karting
    171
    ...change it.
  4. climb
    climb F1 Rookie
    Sep 19, 2006
    4,866
    Atlantic Beach Fl
    Stuart K. Hicks
    Check the ground of the coils and the engine ground etc. Have a z car that did that on and off for years and it turned out to be a ground.
  5. Llenroc
    Llenroc F1 Veteran
    5,495
    Colorado
    Vern
    #5 Llenroc, Jul 30, 2008
    I would point my finger at the battery too or the connections to it. The newer cars (348 up)are really susceptible to batteries not being in top shape.
  6. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Agree on checking the grounds. I had an '84 Mondial QV that did something similar. Turned out that the cutoff switch in the negative ground from the battery was bad, plus the terminal on the battery and at the chassis were corroded. Got rid of the switch, bought a new negative cable, cleaned up the battery terminal and connection on the chassis, sprayed them with battery terminal protector, and also changed the grounding strap on the engine and all the electrical problems/refusal to start cleared up.
  7. jonesdds
    jonesdds Formula 3
    Aug 31, 2006
    2,163
    SB,CA & Park City UT
    Jeff
    I'd concur as well. Had a Mitsu that did exactly as you describe. Corroded battery cables/poor connections and ground. New battery and cleaned up ground and no more problems. Easy, cheap place to start and most likely the problem.
    Jeff
