84 308 GTSi - No Spark | FerrariChat
Discussion in 'Technical Q&A' started by PCosta, Oct 8, 2010.
  1. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    I drove for a good 20 minutes last night (running great) then all of the suddenly it shuts down, temp about 195. I pulled the wire and there was no spark. Fuel pump, filter and plugs have been changed. I had it towed to my home and it started back up. It has done this now a few times. What can I look at next to solve the problem? I appreciate your help.
  2. Ferraripilot
    Ferraripilot F1 World Champ
    Owner Project Master
    May 10, 2006
    17,849
    Atlanta
    John!
    I would venture a guess and say it is a faulty ignition box. Gets too hot, stops working. Cools down, works
  3. Steve Magnusson
    26,806
    #3 Steve Magnusson, Oct 8, 2010
    I'd be less suspicious of the DigiPlex Boxes -- because they'd both have to go bad at the same time to take out both banks (and they'd both have to come back to life together to restore normal operation). Has to be something common to both banks like:
    1. the RPM sensor
    2. the +12V power from the fuseblock to the DigiPlexes
    3. the +12V power from the fuseblock to the Coils
    Quitting after 20 minutes (and rehealing after cooling) matches well with the fuseblock plastic softening and the riveted connections having a problem (and then rehardening after cooling) IMO so I'd start there. One simple thing you can try is adding jumper wires to better connect:
    the A (light blue) wire on the top of fuse B (2nd from the left) -- this line goes +12V when the key is "on"
    to
    the G (yellow) wire on top of fuse B -- this goes to the Digiplexes
    to
    the G (yellow) wire on top of fuse A (the leftmost fuse) -- this line goes to the coils
    (which is what the fuseblock is supposed to do if healthy)
    Alternatively, with a voltmeter you can confirm/deny if you have +12V on those two G (yellow) wires when you are having the problem. Do you have the stock fuseblocks or have you upgraded to something else?
  4. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    I installed Birdmans fuse box a year ago.
  5. Steve Magnusson
    26,806
    That would definitely decrease the probabilty that it is a problem at the fuseblock, but can't really add anything new -- if the two G (yellow) wires (leaving the fuseblock and going to the DigiPlexes and the Coils) are at +12V, but you still don't get spark during starter motor cranking, then the next step would be to check the RPM sensor's function.
  6. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    #6 PCosta, Oct 11, 2010
  7. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Its not likely that there is a problem with the connector, if you need a new one anyway, check an electronics store and ask for a Molex MLX connector.
    I would follow Steve's recommendation and check the RPM sensor, i have seen my share of dead or unreliable RPM sensors while fixing such issues, and a new RPM sensor is relatively cheap. You might also want to check that the ground connection to the Digiplex units is good.
  8. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    The RPM sensors have been ordered.
    Thank you to all!
  9. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    Update - I left the car running in my driveway for about 20 minutes yesterday then she just shut right down. The temp was again about 195. I disconnected one of the crank sensors and connected it again, she started right up but the RPM's was fluctuating from 1000 to 2000. It never stabilized, plus the temperature kept rising and the fans never came on. What do you think definitely the sensors? Thanks,
  10. alhbln
    alhbln Formula 3
    Mar 4, 2008
    1,749
    Berlin, Germany
    Adrian
    Would still suspect the crank sensors, either the crank sensor wiring or the attached cable or connector. A distorted or erraneous signal from the sensor will impact the ignition timing, as the Digiplex is not so advanced to either correct the timing or issue an error code, it just maps the incoming signal to the map and creates the advance timing.
