84 308 QV Missing Part? | FerrariChat
Discussion in 'Technical Q&A' started by PCosta, Jun 30, 2009.
  1. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    #1 PCosta, Jun 30, 2009
  2. 308 milano
    308 milano F1 Veteran
    Jan 15, 2007
    5,327
    Montana
    Kim
    Just went out to the garage and checked my 84 GTB, doesn't have anything there but a 8mm stud,...so it must be all good!
  3. ferrarioldman
    ferrarioldman Formula 3
    Professional Ferrari Technician Silver Subscribed
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    Missing the aluminum cover plate. It also has a rubber gasket that goes under the plate to seal out dirt and oil.
  4. ferrarioldman
    Jun 19, 2002
    1,033
    Summerfield, NC
    Tom Jones
    #4 ferrarioldman, Jun 30, 2009
  5. 308 milano
    Jan 15, 2007
    5,327
    Montana
    Kim
    What would be the point of removing (and not replacing) that cover? ... other than to ruin my evening.
  6. 308 milano
    Jan 15, 2007
    5,327
    Montana
    Kim
    Rifledriver!!!
  7. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    Whoever did the belt job probably did not put them back in...Careful of things that may fall in there like nuts/washers.
  8. 308 milano
    Jan 15, 2007
    5,327
    Montana
    Kim
    Your right Ken, went back to the garage and looked again, its the flywheel cover, probably left it off because its a PITA every belt change.
  9. cockrill
    cockrill Formula 3
    Jan 23, 2008
    1,088
    Columbia, MO
    Jeremy Cockrill
    Wow, my cover is actually there. (I just checked.) It probably means that my belts have never been changed...
  10. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    PITA? Not really. It just take a few minutes to remove and reinstall the cover the rubber gasket...
  11. t3thomas
    t3thomas Formula Junior
    May 9, 2008
    427
    North Carolina
    GThomas
    You should also be very careful not to allow any oil to fall in there when you're changing the filter. It will ruin the clutch disc.
  12. Falcon
    Falcon Formula 3
    Aug 19, 2008
    1,304
    New England Region
    Falcon
    Why would anyone remove this cover for a belt change? The belts are on the front of the engine. This plate is on the back.
  13. t3thomas
    May 9, 2008
    427
    North Carolina
    GThomas
    I would guess since the opeing is there to view the timing marks on the flywheel, when the belts are changed this cover is usually removed to verify TDC of each cylinder bank.
  14. M.James
    M.James F1 Rookie
    Jun 6, 2003
    2,721
    Worcester, MA
    Michael.C.James
    +100
    I am missing this cover as well - its been missing since I've owned the car.
  15. Pizzaman Chris
    Pizzaman Chris F1 Rookie
    Mar 13, 2005
    3,919
    New Hampshire
    Pizzaman Chris
    This reminds me to install mine.
    I have it in a little baggie tossed somewhere in the garage. :eek:
  16. 2NA
    2NA F1 World Champ
    Dec 29, 2006
    18,221
    Twin Cities
    Tim Keseluk
    They are frequently missing.
    Easy to make a replacement from a piece of aluminum.
  17. BigTex
    79,380
    Houston, Texas
    Bubba
    Correct, it's the opposite end of the motor.
    But it's like my air box knurled wheel nuts, they rattle loose and fall off in the road, from all the vibration and the awesome Italian torque....:D :D :D
    Put the new one on with a little Locktite........as noted dumping oil or bolts in there can cause heartache, but sometimes a handful of beach sand will get you home with a slipping clutch....:D
  18. t3thomas
    May 9, 2008
    427
    North Carolina
    GThomas
    It's a small price to pay to replace the cover and gasket preventing anything from falling down in the bellhousing. Although the cover is in place on my car, I remember an earlier post by someone who said that although the oil filter is inverted and if left to cool down before removing, there is always the potential of some oil remaining in the filter when it's removed and dripping into the hole below. Even a small amount of oil can ruin a clutch disc.
  19. t3thomas
    May 9, 2008
    427
    North Carolina
    GThomas
    I'm surprised no one mentioned baggies when as their favorite tool in an earlier poll. It's certainly one of mine!
  20. PCosta
    PCosta Rookie
    Mar 15, 2004
    35
    Metro Detroit
    Thanks for all your help everyone.
  21. Mike C
    Mike C F1 Veteran
    Aug 3, 2002
    6,081
    Southeast USA
    Mike Charness
    I still have my original, but made a replacement out of clear plexiglass so you can actually look into that view port without taking off the cover.
  22. Dr Tommy Cosgrove
    36,434
    Birmingham, AL
    Tommy
  23. Brian Harper
    Brian Harper F1 Rookie
    Feb 17, 2006
    4,078
    San Jose area
    Brian Harper
    When messing with the timing a couple of years ago I droped a nut down the hole and had to pull the bellhousing to retreive it. I not only recommend having the cover on in regular use, but also being really careful during service. That sorta sucked!
  24. Tokyo Drftr
    Tokyo Drftr Formula 3
    Jan 18, 2009
    2,461
    UA-USA-JP
    Ро&#1081
    #24 Tokyo Drftr, Jul 1, 2009
    Even though my cover was on with the gasket, i managed to dump a quart of oil from the filter. Don't ask. Never did it before. The one time my filter did not drain back. Well, i saturated the disk and had to pull the bellhousing. Was a drag.
    As a side note, when i bought my last car, the disk was stuck to the flywheel (hadn't been driven in quite awhile), i was able to loosen the pressure plate and break the disk loose via the opening. That saved me a bellhousing RR.
