84 bbi slow windows - will relays help | FerrariChat
Discussion in 'Boxers/TR/M' started by bl10, Jan 23, 2025.
  1. bl10
    bl10 Formula Junior
    Jun 8, 2011
    440
    Chatsworth, CA
    Barry Leavengood
    Hey guys
    The windows on my new to me 84 bbi are really slow. I'm going to clean and grease the gear drives but need some opinions on adding separate relays for the windows. I added the relays per Paul's drawing to my 78 308 and it sped the windows up a bunch even after new grease. As the window wiring on the bbi is more direct with two rather than three window switchs I'm wondering if the is any advantage to adding the relays to the bbi?
    Barry
  2. bl10
    bl10 Formula Junior
    Jun 8, 2011
    440
    Chatsworth, CA
    Barry Leavengood
    Thanks carlasappone.
  3. Steve Magnusson
    26,772
    Adding relays that provide both +12V and ground (and none of the window motor current goes thru the window switches) = probably yes
    Adding relays that only provide a better ground (and the current still flows thru some of the window switch contacts) = not so much
    What you should do first is supply +12V and ground directly to the window motor:
    If it moves a lot more quickly = electrical problem = add the relays (or replace the window switches).
    If it still moves slowly = mechanical problem = lube window motor, window motor gearbox, rollers, window channel guides, etc..
    samsaprunoff and turbo-joe like this.
  4. bl10
    bl10 Formula Junior
    Jun 8, 2011
    440
    Chatsworth, CA
    Barry Leavengood
    Thanks steve.
    Yeah it looks like the current goes through the switch .Even though the wiring runs are shorter then on a 308 I think it would probably help. But I will try hooking 12 volts directly to the motors and see what it does thank you.
  5. Drew Altemara
    Drew Altemara Formula 3
    Feb 11, 2002
    1,532
    Tuscaloosa, AL
    Drew Altemara
    Sometimes the window channel felt gets pretty sticky due to the lubing. That was my issue with slow windows. Replacing the window channels made a 100 percent difference. Might want to keep in mind in case the above answers do not resolve the problem to your satisfaction.
    samsaprunoff likes this.
  6. bl10
    bl10 Formula Junior
    Jun 8, 2011
    440
    Chatsworth, CA
    Barry Leavengood
    Thanks for the suggestion. Actually I found a large part of the problem. The PO kept a trickle charger on (mounted in the front compartment) all the time. I noticed if I didn't plug the trickle charger in for a couple of days it struggled a little when I first hit tie key. Put a new battery in it last night and the like magic the windows are 100% better. Not perfect but good enough that I don't have to do any thing right away. Wasn't looking forward to the insane window cable installation.
  7. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    I often find new switches makes a big difference.
