84 boxer full restoration | Page 12 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, Dec 13, 2014.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,465
    Canada
    Newman
    Thanks Pap, its awesome to drive a restored one. Everything is tight and clean.
  2. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #277 Newman, Aug 30, 2016
  3. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
  4. ///Mike
    ///Mike F1 Veteran
    Dec 11, 2003
    6,097
    Bugtussle
    That brake pedal box and booster are beautiful and too pretty to hide. Needs to be on display somewhere.
  5. boxerman
    boxerman F1 World Champ
    19,736
    FL
    Sean
    What psitons are those, something newer? have you upped the Cr ratio?
  6. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Custom pistons with larger pins, asymmetrical and a higher ratio.
  7. PAP 348
    Dec 10, 2005
    100,220
    Mount Isa, Australia
    Pap
    Cheers mate, hopefully I get the opportunity to drive one one day. :D
  8. afterburner
    afterburner F1 Rookie
    3,471
    Switzerland
    Urs STEMMLER
    May I know what the black paint on the lower portion of the piston is for? I have never seen that. Thanks for your enlightenment!
  9. 2dinos
    2dinos F1 Rookie
    Jan 13, 2007
    3,032
    Wow! This IS pretty!
    Speechless :)
  10. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,541
    romano schwabel
    this "black paint" is a special coating to reduce the friction
  11. PAP 348
    Dec 10, 2005
    100,220
    Pap
    Teflon coating I am sure. Newman will tell us for sure.
    Here a few different style of coatings on pistons these days.
    Piston Coatings - JE Pistons
  12. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #288 Newman, Sep 21, 2016
    12 pistons in and heads ready.
    Recording stud sizes, thread depth in casting and exposed thread length is critical and there are so many studs that are close in length that if not recorded you're screwed. Note two studs of the same length but very different where it counts.
  13. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #289 Newman, Sep 21, 2016
  14. samsaprunoff
    samsaprunoff F1 Rookie
    4,464
    Edmonton, AB Canada
    Sam Saprunoff
    Indeed, removing, cataloging, and reinstalling takes a fair amount of time... I only did a portion of the studs on my BB's EO service and I have a whole new appreciation for the effort and attention to detail (studs, fasteners, washers, etc) this all takes...
    Cheers.
    Sam
  15. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Hey Paul, were the Boxer studs Yellow Zinc originally? I ask because on my 355, they are Cadmium (silver) I believe.
    Also, may I ask what method you are using to clean up the aluminum cylinder heads? I've considered soda blasting but am hearing some not so good things.....
  16. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    when you open hexnut after factory, like gearbox side covers, you can see original yellow plating under.
  17. jjeffries
    jjeffries Formula Junior
    Sep 4, 2012
    254
    Connecticut
    John Jeffries
    Paul, here's a stupid question: do you remove all those studs via simple double-nut process or something more fancy like a Snap-On collet tool? Best, John in CT.
  18. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    The newer stuff is clear cad like on the 512M and TR engines with some yellow zinc as well. And as mentioned above when you remove a stud you can see the portion that was in the threaded hole still retains its original finish in most cases. Some of it is also just common sense when you cant identify what it was. I did find that some studs are a different colour that are to be in a specific location such as some bellhousing studs where the locating dowels are. Most likely for the assembly line person's benefit.
  19. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Not stupid at all, I have a collet with a variety of inserts for the different sizes but the odd time I do have to double nut if access is an issue.
  20. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    Depends on the casting. Don't blast the diecast parts that for sure! The boxer stuff is sand cast which you can blast but I never use soda. Most times Ill use a chemical cleaner and a brush.
  21. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    On my 355, the color can be seen and determined without removing the studs as they are not that bad.
    I was recently tip off to a plater that might be able to do some of the less common stuff so I need to give them a call.
  22. Dave rocks
    16,047
    Orchard Park, NY
    Dave Lelonek
    Thanks. I've had great success with glass beads on sand cast and die cast parts. Low air pressure and not staying at any spot long works very well. But these are all parts that can be easily cleaned to remove 100% of the media. See my thread in the 355 section - excellent results.
  23. Newman
    Dec 26, 2001
    14,465
    Canada
    Newman
    #299 Newman, Sep 23, 2016
  24. dwhite
    dwhite F1 Rookie
    Paul what tool do you use to torque the 20mm nuts in the valley cyl 7-12 side. I had 2 which I needed to take off and retorque, what a pain to get 90ft lbs. Engine looking like it's ready for the red carpet.
