84 boxer full restoration | Page 15 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, Dec 13, 2014.
  1. 4right
    4right F1 Rookie
    Wow, hard to believe that someone would allow the car to be in that sort of condition. Great work!
  2. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Absolutely awesome! Fantastic work, Paul!
  3. dwhite
    dwhite F1 Rookie
    Removed all that lovely patina and I thought that's the new craze ;-) or is it crazy.
  4. mikael82
    mikael82 Formula Junior
    Nov 18, 2007
    869
    Finland
    Mikael
    "I see what you did there..." ;)
  5. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Lovely work, but you didn't install the original engine so are the before photos of the original engine or the Testarossa engine that is now installed :)
    Pete
  6. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,531
    romano schwabel
    you see at the timing belts that the rebuilt engine is a BB engine, not a TR engine
  7. 4right
    4right F1 Rookie
    You are getting all of his projects confused. Easy to do. ;-)
  8. MotoMeccanica
    MotoMeccanica Formula Junior
    450
    Canada
    Absolutely love it, can't say enough. Keep the photo's coming.....
    Scott
  9. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Oh ... oops ... thanks :)
    Pete
  10. Jakuzzi
    Jakuzzi Formula 3
    Mar 26, 2005
    2,132
    PR, TX, GV
    Jaime
    So true. Was that engine in the car or left outside?
  11. cnpapa24
    cnpapa24 F1 Rookie
    Jan 19, 2014
    3,659
    NOLA
    Chris
    Amazing. Well done, Paul.
  12. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,450
    Canada
    Newman
    Installed in the car and the car left outside for 5 years uncovered.
    Thank you :)
  13. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    #363 Newman, Nov 9, 2016
  14. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    What are the metal tubes in between the inlets on the cylinder heads?
    Pete
  15. turbo-joe
    Apr 6, 2008
    9,531
    romano schwabel
    at the buttom of the tubes there are the spark plugs
  16. ago car nut
    ago car nut F1 Veteran
    5,499
    Madison Ohio
    David A.
    The BB engine is a two valve engine, And the TR is a four valve, thus spark plugs in middle of cam covers.
  17. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Heck, what a weird location for spark plugs for a performance engine. Why not in the middle of the cams.
    And some go on about how the BB's engine is "closely" related to the 312T F1 engine ... er, no.
    Pete
  18. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    Plug is still in the hemi chamber but I agree its goofy. Works though.
  19. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    #369 Newman, Nov 10, 2016
    Boxer head showing plug location. Note intake port has a relief in it for the injector vs a carb head that has no such provision.
    My guess is it wasn't easy to use the 308 plug arrangement for coolant jacket reasons.
  20. dwhite
    dwhite F1 Rookie
    #370 dwhite, Nov 10, 2016
    I don't see a nice big shiney bit in that large squarish hole below the crank end, in the pictures a few posts up. Should look like this soon I'm sure. :)
  21. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    It most certainly will!
  22. PSk
    PSk F1 World Champ
    Nov 20, 2002
    17,673
    Tauranga, NZ
    Pete
    Man everything looks brand new!
    Okay I have a question :). I've read a few times about the engine being above the gearbox and this caused too much weight up high and lead to questionable handling. What are your views of this, is it true and do you have any suggested alternatives that Ferrari should have used?
    Pete
  23. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    The crank is certainly higher than a V configuration but the heads are lower. The engine is surprisingly light. I hear the claims but I don't find I notice this lump behind me that effects the direction Im trying to point the car. Take a 512TR for a spin, lowered engine by 1.25" or so vs a Testarossa and both corner flat and very well on the street. Ferrari took the only approach that would allow a longitudinal 12 behind the driver in a car that looks like a BB or a TR. Full of compromises for sure but Im not complaining.
  24. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    #374 Newman, Nov 14, 2016
    The signal arm like on most ferraris from this era was broken at the pivot. Wanting an easy inexpensive and fast solution I decided to have the part made myself using today's 3D printing rather than go through the moulding process. The part is ABS plastic with a stronger contact arm to resist bending on the electrical end of things and you can replace the part without taking the switch out of the column. You transfer your arm into the new pivot and put it back together. Viola, you're back in action!
    Anyone want one just shoot me a PM.
    Check it out!
    bjunc and GIANNI13 like this.
  25. Newman
    Dec 26, 2001
    14,450
    Canada
    Newman
    #375 Newman, Nov 14, 2016
    GIANNI13 likes this.
