84 boxer full restoration | Page 17 | FerrariChat
Discussion in 'Boxers/TR/M' started by Newman, Dec 13, 2014.
  1. Newman
    Newman F1 World Champ
    Dec 26, 2001
    14,448
    Canada
    Newman
    Thank you Claude it means a lot to hear something like that! You need to visit again!
  2. TerryG!
    TerryG! Karting
    Feb 12, 2017
    155
    Central UK
    Hello Newman, thank you for your response - and over Easter too.
    Seals Direct here in the UK has some similar foam (EPDM) profiles, also C O H Bains. Both have good websites.
  3. wlanast
    wlanast Formula 3
    Jan 9, 2007
    1,178
    Santa Ana,California
    William
    I don't check in as much as I used to, but what a treat to catch up on this project. Excellent work and glad that you share it with us, Paul. Cheers!
  4. samsaprunoff
    samsaprunoff F1 Rookie
    4,456
    Edmonton, AB Canada
    Sam Saprunoff
    #404 samsaprunoff, Apr 22, 2017
    Good day TerryG,
    Having spent a lot of time reviewing the various Seals Direct profiles, I can tell you quite confidently that they do not have the "correct" profile as used on the BB wheel arches. The BB wheel arch profile is an odd shaped profile...at least the ones one my car and the ones offered by Ferrari UK (which I suspect are Cicognani's part) and Cicognani (see pic for comparison of my original to the new replacement profile). Seals Direct EPDM profiles are symmetrical and primarily rectangular, etc. Will they work? I would suspect that their may be a profile that will. However, given that that "correct" ones (well as correct as is currently available) are available from Ferrari UK/Cicognani then it may make better sense to go this direction.
    Cheers,
    Sam
  5. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Considering there are gaps between the seals and wheel wells on some cars I wouldn't worry about the new seals being different. The best setup is the BBi version if you were wanting the best seal.
  6. samsaprunoff
    4,456
    Edmonton, AB Canada
    Sam Saprunoff
    Good day Paul,
    No worries here about the replacement ones not being identical to the originals. Given how "well", ahem, these cars were made the seal's real life function is a bit optimistic :)
    I simply posted the pics to show how the seal is rather unique and unsymmetrical... and thus might be a challenge to find it used on any other non F cars. I have to check the invoice, but I think the Ferrari UK seals (Ferrari part 50091206) were about 50 GBP for a set (left and right).
    Cheers,
    Sam
  7. TerryG!
    TerryG! Karting
    Feb 12, 2017
    155
    Central UK
    Thanks for the advice guys.
  8. Modificata
    Modificata F1 Rookie
    Apr 27, 2003
    2,654
    Hampton, England
    Andy Rasool
    Hey Paul. Amazing job you have done on the BB. I doubt there is another BB worldwide that can compare.
    Reminds me of a BB that I missed about 13 years back. Came into the same garage as my car and the owner wanted to sell for just over £20k. I still cry for not buying it!
    Anyway after reading your entire thread in a day I can't wait to see the finished car. All the best.
  9. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Thank you! Its getting closer.
  10. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
  11. JoeTSI
    JoeTSI Formula 3
    1,433
    Huntsville, AL
    Joe K.
    Wow...just wow. I am in awe of your work and attention to detail!
  12. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
  13. MS250
    MS250 Two Time F1 World Champ
    Dec 10, 2003
    26,572
    Avvocato
    That new camera of yours takes some great pictures ;)
  14. George Vosburgh
    George Vosburgh F1 Rookie
    Better than new!
  15. Dave rocks
    Dave rocks F1 World Champ
    16,047
    Orchard Park, NY
    Dave Lelonek
    Fantastic attention to detail :)
  16. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    I use my iphone6 and its been dropped about 200 times!
  17. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    Thank you :)
  18. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    #418 Newman, Jun 14, 2017
  19. MS250
    Dec 10, 2003
    26,572
    Avvocato
    Now that's funny .... And here I thought it was the camera :D
    Looks great back in the cradle Paul !
  20. Ludwig
    Ludwig Formula Junior
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Really beautiful Paul, will be starting overall reassembly on mine over the next few months.
    A somewhat off-topic question- how are you doing the initial start up. Do you feel a need to "pre-oil"? My thought was to try to get some lubrication by cranking with no compression, fuel etc to try to achieve some oil pressure. Other engines in the past allowed driving the oil pump initially to do this, I don't see this as possible in the boxer engine. Other thoughts would be to manually pressurize via the oil pressure sensor.
    Any thoughts?
  21. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
    In this case as I assembled the engine I used assembly lube on the cam lobes and oil on the bearings etc. Ill spin it over without plugs until I have pressure and away we go. I think manually pressuring it isn't needed.
  22. Ludwig
    Mar 27, 2006
    307
    Redmond WA
    Ludwig Allegra
    Thanks, exactly my plan.
  23. Newman
    Dec 26, 2001
    14,448
    Canada
    Newman
  24. Spitfire
    Spitfire Formula 3
    Nov 16, 2006
    1,602
    Did you write those hand-written numbers on the cylinder heads because they would have been there from the factory, or are they your own "assembly notes" that you'll clean off at some stage?
  25. dwhite
    dwhite F1 Rookie
    That is just such a nice car. Paul, when I hit lotto, I'm sending my car to you. I did just change the piece on the back of the ignition switch, starts everytime now with one turn of the key. :)
