84 brake light problem | FerrariChat
Discussion in 'Mondial' started by westyguy, Dec 14, 2013.
  1. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    #1 westyguy, Dec 14, 2013
    Today I lost both my directional signals and brake light. DeOxit in the white connector solved the directional problems, as there was no power on the second from top connection. I still have no brake lights. My copy of the wiring diagram is a bit fuzzy, as is the one on Ferrari Database. I'm wanting to check the stop light switch but can't tell wire colors and what connection is what. I have the following with the pedal normal (up)
    double green +12
    Red -0-
    Red/stripe +12
    single green +12
    With pedal depressed:
    double green +12
    Red -0-
    red/stripe -0-
    single green +12
    If anyone has a more clear print and can decipher it, I'd appreciate it.
    Thanks,
    Steve
  2. westyguy
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    In doing some more wire chasing and just thinking about it, I'm assuming the switch is DPST NO with one circuit being the large green wires to the red and the second being the smaller wires. It appears the switch is not making so I'm going to remove it and investigate further.
    Steve
