84 QV - Compression results and other questions - need advice | FerrariChat
Discussion in '308/328' started by James in Denver, Jun 30, 2007.
  1. James in Denver
    James in Denver Formula 3
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Howdy everyone.
    OK, so I checked out a 1984 308 QV GTS today, its was VERY nice.
    The owner has a garage and did a compression check while I watched, I read the numbers. The check was done with the engine relatively cool (had been run earlier) and "dry" (I think this means that since it was cold, it did not have oil in the cylinders and no extra oil was put in the cylinders).
    Here are the results:
    Rear bank (towards rear of car, easy accessible bank):
    4 - 147
    3 - 138
    2 - 147
    1 - 152 (before he did this one, he added a booster to the battery, was cranking the engine and the battery sounded just a smidge weak so they added the booster).
    front bank (towards the front of the car, hard to get to bank)
    1 - 140 (opposite of 4 back)
    2 - 149
    3 - 148
    4 - 148
    Any comments on the above?
    I also noticed slight play on the steering, and owner and I measured it. I wasnt sure if it was normal since it's been a while since I've driven a 308. The play was 3/4 to 1 inch each side from the center of the wheel (between 1.5 and 2 inches total).
    Its a 1984 QV, build in Dec 83. I looked under the car, but saw only 1 cat, i thought the 84-85s had 2 cats. The cat I saw was just behind the muffler, where is the 2nd one?
    Thanks for any opinions.
    James in Denver
  2. Joe G.
    Joe G. Formula 3
    1,109
    Los Angeles
    Joe Gazzani
    James
    1983's had two cats (just like the 1980-1982 GTSi's 2 valvers)
    (and a smog pump)
    1984-1985's had one cat,,,,and that concept carried onto the 328
    (with no smog pump and pulse air injection instead)
    looks like you found a nice one
  3. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Thanks, I was quite impressed. The owner was not only incredibly nice, but the owner over-described any minor flaws. Had lets say about 5 minor (and I mean minor) bumps and bruises on the paint (including what looked like a "failed" keying attempt). The car has 33K miles, and I KNOW it original, many many signs screaming that is is, wear on peddles minimal, bolster and interior nealy spotless.
    Anyone else have opinions?
    James in Denver
  4. spirot
    spirot F1 World Champ
    Dec 12, 2005
    15,054
    Atlanta
    Tom Spiro
    I think your compression numbers are OK, I cant remember what they should be, but they seem a tad low, but that could be because the car was not cold from overnight... I would also do a leak down test.... just to be sure.
    I would check the last belt change & valve job, while changing belts is fairly basic, unless you are really familliar with the engine, I would not do it myself.
    The valves are a bit easier, but still not the easiest to do and to do it right you have to take the camshafts out & Measure all the shims...
    Not sure about the single or dual cat's... my old 85 only had one.
    As for the steering play... I dont recal that you should have that much play... the steering rack is a huge pain & expensive to replace.... I think that is normally what goes wrong... with that few miles you may be able to take up the play, but not totally sure.
    does the steering shake side to side when you are driving? if so I would also look at wheel bearings, and front suspension... bushings etc... $5K to re do?? I think.
    dont mean to scare you off, but Caveat Emptor!!!! now than later.
  5. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,580
    Gates Mills, Ohio
    Jon
    Check the usual places for rust - Dec '83 would be the month before Ferrari started rustproofing 308s.
    Hard to say much else. It sounds like the owner is doing the inspection for you, which is a bit odd. If I lived in Denver, I might ask Dave Helms or FoD to have a look at the steering rack (and anything else). None of these cars are perfect, but you want to make sure you know the big items before agreeing on a price.
  6. JF308
    JF308 Formula 3
    Jan 17, 2007
    1,263
    Boulder, CO
    John Feeney
    Don't nickel and dime the inspection. Everyone on this chat talks about the importance of a PPI. I'd recommend paying for a good look/see, not just pointed ad hoc investigation regarding the obvious things the owner has declared.
    Compression/Leak down should be done under the optimum conditions as determined by the Ferrari tech. Not just while you happen to visit. (I dont know the conditions myself, but have listened to FChatters talk about the variances in compression driven my testing methods and conditions.)
    It will be the best $500 or so that you can spend for the peace of mind that these purchases require -- and even at that, there will be gremlins unknown that need to be chased after purchase, so save some sorting out maintenance dollars aside, too, even if you think it needs nothing else. A little sorting does not make it a bad car, just don't spend your last nickel on the car itself otherwise it will make it a BAD EXPERIENCE.
    I hope this one works out for you -- and we can hook up for a tour of the mountains.
  7. Badman
    Badman Formula 3
    Mar 4, 2007
    1,116
    Gotham City
    Bruce Wayne
    Compression numbers don't seem too bad to me. Should be like 170-180 best case, but it depends upon all kinds of factors (like the engine being hot, the throttle plate fully open, the gas line disconnected, probably more I've forgotten). They're all close together which is the most important part. One of the cars I had PPI'd had readings much closer to 100, and even that people I asked weren't very concerned with because the numbers were well balanced between cylinders.
    As to the steering, it shouldn't have that play. How do I know? Because my car has similar amounts of play in the steering, and the other cars I've driven are rock solid all the way through, no play anywhere. You can send your rack out to be rebuilt for like $400-$600, but I've heard removal/install is a pain.
  8. Artvonne
    Artvonne F1 Veteran
    Oct 29, 2004
    5,379
    NWA
    Paul
    Every mechanical repair book written in the last 40 years or more, whether its a motorcycle, a snowmobile, or a boat, lists 10% as the minimum allowance between cyclinders. Your well under that. Regardless of the engine being at optimum temperture, its still very even, and I would suspect it would tighten up a bit if the engine were good and hot right after a run. And as simple and fast as it is to do, I would do it again hot just for the piece of mind.
    And James, unless your a mechanic, and even if you are, get some other eyeballs on the car. Its far to easy to let passion blind you, and a good friend or mechanic may see things you just either cant, or wont. To many times we buy somehing and bring it home, and in the dawn of the new day we see all its foibles we missed the night before. OTOH, I bought a Mercedes roadster after it failed a PPI, because it had to many small issues. I still bought it because it was the prettiest color of that car I had ever, or have ever yet seen. Sometimes ya jus gotta have it.
    But just for clarity, compression tests should be done only on a hot engine, throttle fully open, good battery and all spark plugs removed. You can pull the pump fuse to keep from fouling the motor. Because we arent talking a mundane daily driver, but an engine worth tens of thousands of dollars, the compression test should be a simple pass or fail. Adding oil to to a cylinder to see if any recorded low compression reading is rings or valves is rather moot, because if an engine like this has bad valves, you must assume the rings could need works as well, so just a tired engine is always suspect, and should be valued accordingly IMHO. Once you start opening it up, you never know how far the rabbit will lead you down the hole. And for this reason, leakdown tests are equally moot IMO. There have been so many postings of leakdown tests taken by people who have no clue how it works, that unless I was doing it myself I would question it. A compression test is so simple and hard to screw up, that it should almost be the defacto test of a Ferrari engine to determine a pass/fail grade. I would only want to do a leakdown on cars with equally low compression, to determine if there is a fault accounting for the low compression. Low compression would most likely be caused by faulty valve timing, once the engine is ruled out
  9. Bullfighter
    Jan 26, 2005
    22,580
    Gates Mills, Ohio
    Jon
    Possibly a dumb question, but does the altitude affect those numbers?
    He's in Denver.
  10. hardtop
    hardtop F1 World Champ
    Jan 31, 2002
    11,293
    Colorado
    Dave
    James,
    The numbers are good and consistent. They are always lower in Colorado overall because of altitude than at sea level. I would have someone check the suspension and steering rack. Racks do go bad. Suspension rebuilds are not cheap. Sounds like it is probably a good car though. I'll give you 15K for the Boxter.
    Dave
  11. abarthracer
    abarthracer Formula Junior
    Dec 6, 2003
    373
    Falmouth, Cape Cod
    david S.
    Hey James, those compression # are excellent, especially on a cold engine, as for leakdown, If the compression # were low then I think it would be important, remember at colorado altitude, the #'s will be lower anyway. The steering play, well remember it is a 23 or so year old car, this is to be expected. If it really bothers you have the rack re built for the $400 to $600. It sounds like a good car though, and if they were willing to do a comp. test for you as you were standing there, I think that is a good sign. I purchased a Mondial from a family in Louisville, at the time they had a 308 and a TR, I looked the 308 my self, and it was too a very nice car, but they were really not interested in selling it about 4 years ago. If by chance this is the same 308, I wouldn't worry about a thing, the Mondial was exactly as described, and I drove the hell out of the car before finally buying my F355.
    Dave
  12. ForzaMaranello
    ForzaMaranello Karting
    Jul 15, 2006
    234
    Louisville CO.
    Robert T
    Hey Dave, yes this is the same 308, I have decided to buy a 360 this is why I am going to sell Bella. I hope you enjoy your 355, did you sell the Mondial or do you still have it?
    Robert
  13. abarthracer
    Dec 6, 2003
    373
    Falmouth, Cape Cod
    david S.
    360? Nice, Yes I did sell the Mondial after buying the F355. If by chance you and James in Denver do not deal on the 308, PM me. I am interested! Please let me know as soon as possible.
    Dave
  14. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Hey, don't snipe this car out from under me :) That's already happened to me once!
    I should know by mid-week at the latest.
    James
  15. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    Hey Jon,
    I don't have a checklist handy and haven't tried search, where should I look for rust on the 308's?
    The owner pulled the car up on a rack, and it was very clean and straight. I noticed a few very very VERY minor rust spots, but I can't remember where they were. There are NOT rust bubbles on the body anywhere. I think one of the weld seams, but it was very minor at best.
    James
  16. James in Denver
    May 23, 2006
    2,136
    Centennial Colorado
    James in Denver
    The belts were done by the owners, real italians :), in 2006, verified.
    They didn't mention valves and shims, and I do have the records with me to check if it was done prior to them buying the car
    I think its the steering rack..... ouch... argh.... expensive.....
    I didn't notice ANY shake in the steering wheel and driving it, it had no pulls etc. However, the bushings were dry rotted a bit, still there, but definately original.
    The good news is, as i said, this car is verified and trustworthy as a 33K mile car, the current owner has owned it for 16 years and put 3K per year.
    I think it will need the brakes flushed as well, a couple of times it was a bit slower to respond to stopping.
    All that said, its a NICE car and I'll have a decision by mid-week.
    James
  17. jimshadow
    jimshadow F1 Veteran
    Feb 19, 2006
    6,246
    Indiana/North Carolina
    JIM
    The steering can have zero play and the rack can still be in need of a rebuild. The way we checked mine was to get it in the air and grab the front wheel, moving each to the left and right. My left wheel moved ever so slightly while the right did not. The recommendation by Tillack was that the rack be rebuilt at some point in the future, but not necessairly today.
    Good luck, I hope this is the one!!!
    JIM
  18. hardtop
    Jan 31, 2002
    11,293
    Colorado
    Dave
    This is likely to more than needing a flush. Brake trouble can be very expensive. Get it checked out.
    Dave
  19. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    James,
    Sounds like you found a good one. If the price is right, don't let some needed work scare you off on it. They all need some work to bring them up to 100%. That's an expected part of buying an older car. And if you're handy and enjoy doing it, you can do a lot of the work yourself. These are not hard cars to work on.
    BTW, the brakes on my '78 are as you describe, a bit mushy. I just picked up some new brake lines and Porterfield R4S pads, and will be changing them and flushing the system soon. Easy job. The old hoses tend to get soft, making the pedal feel less firm. R4S pads give a nice crisp bite for stopping.
    Good luck and when you make the deal, post up a couple of pictures for us.
    Regards,
    Steve
  20. Bullfighter
    Jan 26, 2005
    22,580
    Gates Mills, Ohio
    Jon
    Some of the common places are the door bottoms, base of the windshield, lower body welds and sharp corners such as found those fender louvre cutouts and behind the rear quarter louvres where water can collect (paint tends to crack at sharp corner joints due to normal body flexion - not just on Ferraris).
    There's trivial surface rust (where a scratch wasn't touched up properly) and terminal cancer rust, where for example the doors are rusting from the inside out. Definitely you should distinguish between those types. I've seen rust on the '84-'85 308s as well, but not as vigorous as on the '77-'83 cars, which seem to rust in the morning dew.
    EDIT: Also, U.S.-spec 308s seem to have chronic rust in the exhaust 'diaper' below the bumper. This is easy to fix and I've seen it on otherwise phenomenal cars, so don't pass a car up just because of a spot of rust there.
  21. Sean F.
    Sean F. F1 Rookie
    Feb 4, 2003
    3,066
    Kansas
    Sean F
    The belt change is easy, familiar with the engine or no. The cams do not come out to change the shims. In fact, you need to leave the cams in to check them. If you want to take them out to change the shims, by all means, but it is certainly not required that you do so.
  22. eulk328
    eulk328 F1 Rookie
    Feb 18, 2005
    2,800
    F683
    You're also going to get different numbers from one compression tester to the next. Just because it reads 150 psi, for example, doesn't mean it's not actually 140 psi or 165 psi etc. Depends on the quality of the instrument, maybe age and handling. Certainly you should get consistent readings from repeated measurements, on the same cylinder, spaced only a short time apart.
    Erich
