'84 starts and immediately dies | FerrariChat
Discussion in 'Mondial' started by westyguy, Aug 18, 2014.
  1. westyguy
    westyguy Formula Junior
    Apr 27, 2009
    252
    Huntsville, TX
    Steve
    #1 westyguy, Aug 18, 2014
    I had a miss in my 84 about a month ago and haven't had time to look at it until today. Now it starts then dies after about a second. Any typical issues causing this before I start checking voltages in the F.I. system?
    Thanks,
    Steve
  2. Bell Bloke
    Bell Bloke Formula 3
    Dec 6, 2012
    1,839
    Fuel pump? Worth a first check
  3. MvT
    MvT F1 Rookie
    May 25, 2013
    4,261
    The Netherlands - NH
    Tijn
    sounds like a fuel problem rather then a voltage one.
  4. ronfrohock
    ronfrohock F1 Rookie
    4,156
    MA
    Ron Frohock
    It turned out to be a relay that was located in the area underneath the antenna at the back of the car. It had something to do with the FI System. Frequency Valve if I recall correctly.
    There was a thread back then that Steve Magnussen (SP?) contributed to. He outlined the diagnostics and was extremely helpful. Ill try to find it and forward it to you.
    - Ron
  5. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    my 85 had a similar issue.if you look at your relay panel you have a start relay and a run relay.my start relay was ok so it would start but as soon as it did the faulty run relay shut it off.hope this helps
  6. David Lind
    David Lind Formula 3
    Nov 19, 2008
    2,248
    David Lind
    Where are the "start" and "run" relays located? In the trunk w/ the ECU & frequency valve?
  7. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    Can you keep it going with starter fluid sprayed into the air intake?
  8. srephwed
    srephwed F1 Veteran
    7,093
    street,md
    fred brown
    they are in the fuse/relay panel.you can go to Ferrari forums and view the repair manual and print out what each fuse and relay does.I carry spare fuses,relays and a copy of what they do in my tool kit.hope this helps and good luck
