85 308 QV interior code HELP | FerrariChat
Discussion in '308/328' started by firedude308QV, Jul 1, 2008.
  1. firedude308QV
    firedude308QV Karting
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    I am attempting to find out what the original color was for my interior. I have searched this forum and the internet for months now. The leather in my car has been dyed before. I know there are two colors offered by Leatherique, Saddle I and Saddle II. The present color in the car is somewhere in between.
    I attempted to contact Ferrari via the Ferrari Owners site and Ferrari directly. They said they could not help me, which seems pretty unsupportive.
    Does anyone have an 85 QV, and if so do they know their interior code? I have heard sometimes it is sometimes in their owners manual.
    Any help would be much appreciated.
    Thanks,
    Bill
  2. Bullfighter
    Bullfighter Two Time F1 World Champ
    Jan 26, 2005
    22,594
    Gates Mills, Ohio
    Jon
    If it's tan, it's probably 3218. Check the GAHH.com website - they supply replacement leather for Ferraris and it's quite accurate.
  3. 308 GTB
    308 GTB F1 World Champ
    11,717
    New Jersey
    Barry Wolinsky
    #3 308 GTB, Jul 1, 2008
    You can contact the dealership where the car originally sold. They might have kept records.
    Here's the Algar stock card for my 1976 GTB:
  4. RichardAguinsky
    RichardAguinsky Formula Junior
    Nov 12, 2007
    478
    Palo Alto, Californi
    Richard Aguinsky
    I just went through the same pain with mine. I have a red interior, which is supposed to be VM3171 from Leatherique. I sent in a sample to compare and it was off. Another fchatter had the same issue with their Red VM3171. I ended up doing a color match by sending a sample.
    If Saddle I and II do not look like they match, then you may need to send them an undistrubed sample of your leather.
    Is there any part of your car that was not dyed? Under the seats? Remove a door panel and look inside? All they need is about one square inch sample. It will be the best $95 you'll spend. My interior looks great now.
    Remember to apply the Rejuvinator and Pristine clean MANY times before dying.
    Good luck and send pictures.
  5. Bullfighter
    Jan 26, 2005
    22,594
    Gates Mills, Ohio
    Jon
    #5 Bullfighter, Jul 2, 2008
    Saddle I may be the 3218 color code, which was used on the '70s and '80s cars.
    Saddle II may be the 3228 color code, used on the 355 and later cars.
    Unless your car was kept indoors for the last 30 years in storage, it will be difficult or impossible to tell the original color without some kind of factory certificate, as Barry posted.
    When I had my 328 interior redone, we disassembled the seats and removed the old leather, revealing the original/preserved color that was tucked underneath the seat cushion (on the left, below). Everything else had been changed by years of sunlight and dyeing -- and my interior was in pretty good shape prior to the re-upholstering.
  6. firedude308QV
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    Thanks for all the information guys. Was the 85 QV available with both the Saddle I and the Saddle II interior color? I recently saw an 84 QV unrestored with the original Saddle I interior. It is definitely more yellow/tan than the Saddle II's orange tint.
    I would like to keep it as original as possible.
    Thanks again,
    Bill
  7. Bullfighter
    Jan 26, 2005
    22,594
    Gates Mills, Ohio
    Jon
    Saddle II came later and is darker. Back in the '70s and '80s, when men were men and we didn't spend weeks picking out leather swatches for our cars, there was only one 'tan' and it was 3218. They also had crema, red, blue, grey and black.
    Now I'm sure the Ferrari dealer has a big hardbound volume of all the shades of tan...
  8. firedude308QV
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    Thanks for all the info. Does anyone know which of the many books on the 308 are best for finding more information? When I took my seats out, I discovered they were redyed with different shades of dye. I really want to redye to the original color.
  9. tnowak
    tnowak Rookie
    Apr 13, 2004
    23
    New Hampshire
    Tom Nowak
    I have an 85 QV and the color of my interior is the 3218 saddle I. The only thing different with my interior is the piping was ordered as black with this color.
  10. firedude308QV
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    #10 firedude308QV, Jan 21, 2009
    My search for the correct color and code is still very confusing. I know one thing for sure, my interior is beige. The same color codes are different shades. Saddle 3218 from Leatherique and GAHH as seen below are very different.
    The "Original Ferrari V8" book list the color as VM4208.
    A 07/15/1989 Ferrari service bulletin says VM4208 replaced VM3218 in 1989.
    Ferrari has not been able or willing to help.
    I really want the interior to be the factory original color. If anyone has a 1985 with the "beige" interior can you please post a picture? Even better would be a Algar stock card with the color code. Any help would be appreciated.
    Thanks,
    Bill
  11. t3thomas
    t3thomas Formula Junior
    May 9, 2008
    427
    North Carolina
    GThomas
    I went through a similar experience and finally cut a small piece from underneath a seat and sent to Leatherique. Turns out the original color for my car was 'creme', which I never would have guessed from the color samples on their web site. It was a perfect match and the interior now looks almost factory new. You should follow their instructions to a 't' including the stripping and wet sanding, but the results will be dramatic. Btw, I applied the stain w/ an air brush and it gives a more monolithic, textured appearance. Also, it is probably more likely that the intreior color is creme if the exterior color of the car is something other than red. Mine is Black, btw.
  12. firedude308QV
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    I forgot to mention my exterior is Rosso Corsa.
  13. Jeff Kennedy
    Jeff Kennedy F1 Veteran
    Oct 16, 2007
    6,847
    Edwardsville, IL
    Jeff Kennedy
    #13 Jeff Kennedy, Jan 22, 2009
    Have you done the request for your Heritage Certificate from the Ferrari Owner's website? The certificate will give the interior color code. Here is the certificate for my QV.
    Jeff
  14. magnum
    magnum Formula Junior
    Feb 21, 2008
    877
    Barcelona, Spain
    Antonio
    Hi.
    I've a 1983 308 QV red on tan. I've asked the Ferrari Owners site and they told me that the interior tan colour code is 3218. So go for it.
    Cheers
  15. firedude308QV
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    I decided to go with Leatherique and the 3218 color. Can anyone recommend a good sprayer or airbrush brand and model to use?
  16. magnum
    Feb 21, 2008
    877
    Barcelona, Spain
    Antonio
    Hi Jeff.
    I'm curious. When you asked for the Colour Certificate? I'm trying to have mine and the Ferrari Owners site they told me that's impossible, only for carb cars until 1980... I'm trying several times, and I receive all the time the same answer: not possible! There is a back door to receive the Certificate? We've to pay something? I think that there are several Fchatters with the same question.
  17. Jeff Kennedy
    Oct 16, 2007
    6,847
    Edwardsville, IL
    Jeff Kennedy
    I just filled in the request through the owners site and it was available to download a couple of days later. No charges or grief.
    http://www.ferrariowners.com/cms/public/cmd/ViewTemplate?templateNode=PAGE070809020651COLORI
    I will admit that one has to correctly navigate the website to get to the proper place.
    Jeff
  18. magnum
    Feb 21, 2008
    877
    Barcelona, Spain
    Antonio
    Hi again Jeff.
    No problem to navigate to the appropiated part of the Ferrariowners site. The problem is that after filling the web page with the data, they sent to me an e-mail telling me that the certificate is only for carb cars until 1980. Your car is injection and a 1984 car, so... Why they don't want to do the Certificate? Why they sent to you the Certificate? This is the question?
  19. captglen
    captglen Formula 3
    1,790
    West Palm Beach, Fl
    Glenn L.
    Hi ,
    I went to the Ferarri Owners site and tried to get the color certificate but I do not understand italian.
    After I put in my model it asks me for 2 more number, Is the 1st my serial number and the 2nd my engine numer ???
    Captglen
  20. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    There was a brief period of time at the very beginning of 08, when they changed over the website, you get get that certificate for the injected cars.
  21. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Mike C from FChat redyed his seats using Leatherique but not with their method. Leatherique used to have the info posted on their site but the last time I was there it was gone. Here is the link Mike sent me: http://www.fca-se.org/conc_leather.htm.
  22. irondogmike
    irondogmike F1 Rookie
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    #22 irondogmike, Feb 21, 2009
    I got mine after trying for a year,just about four months ago,you do have to fill out the form right meaning vin# and engine #,and then finding it in the right place to download,you see mine was there aleast two months b4 and didn't know it also at the beginning they also told me only carb's,I have a 85qv,also it might help if you have register your car on their site to
  23. BwanaJoe
    BwanaJoe Formula 3
    Oct 23, 2006
    1,764
    Former Space Coast
    Joe Burlein
    Sweet! You are the first person I've heard of that has pulled that off.
  24. Jeff Kennedy
    Oct 16, 2007
    6,847
    Edwardsville, IL
    Jeff Kennedy
    I waqs able to get my Heritage Certificate very easily in the fall. Register as an owner then fill out each line on the website form as requested.
    My certificate was issued September 13, 2008.
    Jeff
  25. irondogmike
    Sep 8, 2006
    2,532
    San Diego area
    Michael Tucker
    thats what I did,I think thats part the reason we were able to get the certs,
