85 308 QV spark plug gap | FerrariChat
Discussion in '308/328' started by nevets308, Jan 2, 2013.
  1. nevets308
    nevets308 Rookie
    Jul 20, 2012
    37
    So California
    Steve
    I need some advise on the proper plug gap, I am replacing my spark plugs with a set of brp7eix plugs.
    I have an 85 qv with 7800 miles on it. When i checked the gaps on the new olugs they very from .30 to .52
  2. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    .025". Be very careful not to touch the center electrode on these plugs while adjusting the gap.
  3. Wilson308
    Wilson308 Formula Junior
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    +1, use a feeler gauge you can hold up and measure by eye, the electrodes on iridium plugs are extremely fragile. Also, those plugs have resistors built-in, so you might consider replacing the extenders with black non-resistor type if you still have the red resistor ones (you can check with a multimeter, should be around 2.5K ohm, but some of mine were up to around 5K). Not a big deal though, it should run fine with either, unless an extender is failing and showing significantly higher resistance.
  4. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    Regarding extenders - you must measure the extenders to determine if they are resistor-type or not. You cannot go by color. A non-resistor extender will read less than 1 ohm.
  5. Wilson308
    Apr 27, 2012
    635
    Arkansas, USA
    Wilson
    Apologies for any confusion, you are correct, the color cannot be trusted by itself.
  6. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,322
    Surprised you are seeing such variances on Iridium plugs - the 3 or 4 sets I have fitted have all been identical out the box.
    Be very careful trying to adjust them - they break easily.
  7. FasterIsBetter
    FasterIsBetter F1 Veteran
    Jul 22, 2004
    5,855
    NoNJ/Jupiter FL
    Steve W.
    Ditto. It was my understanding that you should NOT try to adjust the gap on iridium plugs, that they come pre-gapped from the factory. I've checked the NGK ix plugs I've gotten in the past, and they were all pretty much around .030-.032, IIRC. I've installed them as is in a 308 with Electromotive and in my 328 stock ignition, and they have worked just fine right out of the box.
  8. Rifledriver
    37,106
    I adjust them routinely. Why not? It's not done with a hammer and chisel you know.
    The set I installed last week ranged from .014 to .04
    And I havn't installed a plug with a .032 gap since Chevies had carburators and points.
    Don't touch the center electrode?
    Whatever.
  9. pad
    pad Formula 3
    Sep 30, 2004
    1,426
    Tequesta, FL
    Paul Delatush
    #9 pad, Jan 3, 2013
  10. Rifledriver
    37,106
    And many tools are manufactured to adjust them.
  11. BigTex
    79,386
    Houston, Texas
    Bubba
    Gently tapping them on the driveway???
    Happpy New Year!!!
