85 308 QV throttle hesitation when warm | FerrariChat
Discussion in '308/328' started by firedude308QV, Jan 11, 2023.
  1. firedude308QV
    firedude308QV Karting
    Nov 22, 2007
    116
    Tarpon Springs, FL
    Bill Scott
    I have spent the last week reading all the related posts on the issue I am having. This includes Carl Rose's among several others. Yes, I have used the search feature before posting. lol
    The car starts on the first attempt when cold or hot and idles at 950-1000. It runs fine when first driving off with great acceleration. When the car gets warm after approx. 15 minutes, the acceleration is poor starting around 2500 rpms. The car seems bogged down and has very low power. When parked, the car easily revs up to the yellow/red line. I always had vehicles which ran better when hot or at temperature.
    I have reviewed the Ignition and injection section in the Mondial Workshop manual, the Service Bulletins and the Gasoline Fuel-Injection System K-Jetronic book.
    I performed a fuel system pressure check with the following results:
    Cold 2.0 bar (29 psi)
    Warm 3.0 bar (43.5 psi)
    System 4.0 bar (58 psi)
    Pressure after 10 and 20 minutes 2.2 bar (33 psi)
    Pressures per Service bulletin with my WUR (0 438 140 132)
    Cold 2.0 - 2.5 bar
    Warm 3.3 - 3.7 bar
    System 4.7 - 5.4 bar
    Pressure after 10 and 20 minutes 2.7
    Question, what is the cause of the poor acceleration and apparent related low fuel pressures?
    The threads I have read mention the WUR as a possible culprit. What else may be causing the issue?
    Any help and suggestions would be much appreciated.
    Thanks,
    Bill
  2. Steve Magnusson
    26,785
    I would not worry about the WUR warm control pressure being low until you fix the System pressure being low -- maybe bad fuel pump, clogged screen at fuel pressure regulator section of FD, something gummy up the plunger motion of the fuel pressure regulator, blocked fuel filter, kinked fuel line, etc.. Have you done the fuel volume return test going back to the tank with the engine not running?
  3. Island Guy
    Island Guy Karting
    Feb 20, 2020
    134
    Island Guy
    For starters, your system pressure is too low. The stated WUR pressure are based on a FP pressure of 5 bars. Check the inlet screen on the FD for debris, then do a pressure/volume test on the FP.
