85 308 replace parts w/ factory or upgrades. | FerrariChat
Discussion in '308/328' started by nevets308, Mar 12, 2013.
  1. nevets308
    nevets308 Rookie
    Jul 20, 2012
    37
    So California
    Steve
    I am taking my 85 308 QV in for a major service due to age. I am changing all rubber brake hoses, fuel hoses and cooling hoses as well as belts and gaskets. I need to decided to replace parts with as many factory ferrari parts and keep it as original as possible, or do I use upgraded parts. I do not plan on selling my car any time soon. I know there are alot of opinions on 308's with low mileage, but this car only has about 7800 miles on it. The last belt change was in 2007 with 1500 mile on it since. I would like some opinions on factory or after market parts.
  2. Nuvolari
    Nuvolari F1 Veteran
    Sep 3, 2002
    6,638
    Toronto / SoCal
    Rob C.
    The parts offered at the dealer are generally of very high quality with an equally high price to match. Quality aftermarket parts can give you advantages over OEM if you know exactly what you are buying. In addition there are savings to be had in most instances. You need to know that most of the parts the dealer sells are not the same spec as when your car was made. Over 30+ years many Ferrari suppliers are either not in business or no longer make parts for the 308. Ferrari themselves source from the aftermarket for their own dealers from time to time so don't fall in love with the 'yellow box' too much. As far as consumable service items go, as long as it looks like original and is of high quality you will not be affecting the value of your car by going aftermarket.
  3. PT 328
    PT 328 F1 Rookie
    4,004
    Be sure to check out the cross reference parts page at the top of the 308/328 section.
  4. BigTex
    79,380
    Houston, Texas
    Bubba
    Well, specifically:
    Ricambi is selling specific Hose Kits, that have specially fabricated hoses for modern fuel blends.
    They also offer a similar kit for the coolant lines, extra heavy duty (I am unsure if it has the long ones you'd need between the head nipple and the heater core in front, so check that)..
    On the subject of the heater hose head nipple, the OEM one is cast aluminum, and will be weak from corrosion, so go instead with the Hill Engineering machined stainless steel replacement (Ricambi has that too!)
    Brake calipers lines...for sure replace, your call about an outer braid covering, some folks swear a stainless braid gives "harder feel".....they have sensitive feet! But going with some nice slotted discs (Brembo or others), some Porterfield pads, and new rubber lines and brake fliud WILL make a nice difference. new fluid is actually good annual maintenance.
    So off the top of my head there's four areas you actually would NOT want to stand at a Ferrari counter and order, as modern replacements are better.
    The modern gas is VERY hard on any rubber components, fuel pumps and carbs are dying daily.
  5. BigTex
    79,380
    Houston, Texas
    Bubba
    Belts and gaskets I would go with Factory parts, but TRutlands is having a Spring Sale right now on "Service kits"...
    Hill Engineering tensioner bearings (Ricambi again!) are better than Factory ones, at this point...
    Some aftermarket knock off gaskets and seals will bring you trouble, AVOID!
  6. Fairview
    Fairview Formula 3
    Mar 16, 2009
    1,109
    Waynesboro, Virginia
    Jeff Ward
    Amen. I think I owe The Carreaper about $2000 for starting the cross reference thread....
  7. GrayTA
    GrayTA F1 World Champ
    15,130
    Deep South
    PDG
    The other factor to consider is that a lot of the things in the little yellow boxes MAY have been sitting for years as NOS which leads to their own breakdown and failure almost right out of the box - ask me how I know.
    PDG
  8. shawxhurst
    shawxhurst Formula Junior
    Nov 6, 2006
    672
    San Diego
    Steve Hawxhurst
    Keep in mind that the factory only manufatured the engine, tranny and body and frame. For the rest of it they dug into the Fiat parts bin or bought bits from the same suppliers that produced parts for VW, BMW, Porsche and others. The cross reference thread is a great way to save a few bucks and get the same or better quality. In general, I've found that the major parts houses like Ricambi, TRutlands, etc are cheaper to buy direct than from independant shops. In retaliation the indepents can give you some crap about "we can't warantee the work because you didn't buy the parts from us". Sorta can't blame them as they may have a big investment in parts on hand but that's no excuse for "predatory" pricing
  9. nevets308
    nevets308 Rookie
    Jul 20, 2012
    37
    So California
    Steve
    Is the much difference in US vs euro parts?
