'85 308 Will Not Start | FerrariChat
Discussion in 'Technical Q&A' started by David Coutta, Dec 20, 2004.
  1. David Coutta
    David Coutta Rookie
    Dec 20, 2004
    3
    Hello Ferrari Lovers, or haters as the case may be, I have a problem with a 1985 308. The car was just freshly serviced and brought back from Ferrari of Atlanta to me here in Birmingham, AL. The car drove like that "Bat" we all hear about. I drove it into town and left it at a detailer for some touch up work on the paint finish around the top to fender connection. The shop drove it over to their detail booth and all ran fine. I stopped by one day to show the car to someone and the engine will not even turn over. The electrical seems ok but, when I turn the switch to the start position you can hear something, back at the engine bay, going on, like a buzz or somethin.
    The engine is just dead and it happened that suddendly. There is no attempt to even begin the process of turning over. I am at a loss and the car is "dead in the water" at the shop. Can anyone shed some light on what this may be and HOW do I get it started and back home? HELP !!
    D. Coutta'
  2. alohamickey
    alohamickey Karting
    Sep 23, 2004
    180
    San Clemente CA
    Mickey
    When a car doesn't start, it is usually Fuel, Spark, or Air.
    The buzzing could be your fuel pump. Does the car turn over and not fire?
  3. f355spider
    f355spider F1 World Champ
    18,055
    Well, I would start by assuming you have a dead battery. Remove the spare tire and battery cover and try jump starting the car. If it starts right up, then you know you need a new battery. The size is a group 34R. It is like a group 34 but has the terminals in the reverse positions.
    Good luck.
  4. Michael Collins
    Michael Collins Formula Junior
    Apr 6, 2004
    272
    Shanghai/Melbourne
    Could be the starter dog is stuck, put it in gear and rock it back and fore a bit and try again.
  5. David Coutta
    David Coutta Rookie
    Dec 20, 2004
    3
    Thanks for some of the suggestions. I will try rocking the car, etc. For more info from this end .... the engine will not turn over at all. It is not that it will not "fire" it will not even turn over. The battery is good and I have even used a Jump Box thinking it was a dead battery but, it did not help at all in making the engine turn over. It is as if there was a dead battery but again, all lights etc work; the engine just sits there "dead in the water".
    I also thought of the noise I hear in the back as being the fuel pump but someone listening at the engine area said it sounded more like spark plugs trying to spark inside the engine ... that is just a guess on their part.
    One of my thoughts was maybe a dead spot in the starter but how would you get the starter turned over to reposition if that was it? The car was moved into the detail area within the shop and the car still did not start up ... but ... they would have moved it in netural and not in gear ... I will call them to ask for them to put in gear and rock it to maybe move the starter "dog"; What is the "DOG" by the way???? Where is the starter to maybe check the connection to it? I am in a real pickle here trying to get this car back home and away from the detail shop.
    Thanks, People for your help here ... I do appreciate your comments.
    David
  6. Oengus
    Oengus F1 World Champ
    Dave,
    the clicking is the fuel pump. I would try the battery and connections first.
  7. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Dave,
    Welcome to the 308's biggest weakness: electrical system. The good news is that it's probably something simple. The bad news is that sometimes troubleshooting these issues is hard if you aren't good with electrical concepts.
    If you turn the key and you hear the fuel pump but no starter, it's not a tooth engagement issue of the starter. I mean, the fuel pump isn't that loud. If the starter were turning and not engaging, you would know it. The way to tell the difference is that the fuel pump comes on in position 1 of the key. When you turn to the start position, you should get the starter. If nothing changes in terms of sound, the starter isn't turning or trying to turn, and that is an electrical issue, not mechanical.
    Check the schematic (owners manual) and figure out which relay drives the starter. Follow the circuit. I'm sure you will find that a relay or fuse is not working. My advice...start by pulling every single fuse in the fusebox, clean the contacts on the fuses and the fusebox with something abrasive (220 or higher grit sand paper works well) and put them all back in. The fuseboxes on 308s totally suck beyond words. They cause most electrical issues. If this fixes it, save yourself a lot of future aggravation and build/buy some upgraded fuseblocks that use a better design. (Search the archives, this is a common and easy upgrade).
    Good luck
    Birdman
  8. 308GTS
    308GTS Formula 3
    Dec 27, 2001
    2,223
    TN
    On an 85 you shouldn't hear the fuel pump in the second position unless you have the safety switch bridged.
  9. Steve Magnusson
    26,931
    Dave -- If you had a "dead spot" on the starter motor commutator you would hear the starter solenoid click very loudly (when you turn the key to the "start" position) even though the starter motor doesn't spin (so I wouldn't suspect that as the problem if you don't get the loud starter solenoid click first).
    The good news is that there are no fuses or relays involved in the 308 start command stuff. Do the gauges (e.g., the oil pressure warning light) come "on" when you turn the ignition key to the "run" (not "start") position? The +12V power going to the ignition switch comes from the smallest of three wires leaving the "+" battery terminal so if your dash is completely dead check that first.
    If the power to the ignition switch is OK (i.e., your oil pressure warning light does come "on" OK), you could try removing the "G" relay shown in the OM and measure the voltage from the "87" slot in the relay socket (the bottommost horizontal slot) to a good ground (the same "start command" signal that should be going to the starter solenoid also goes to relay G to run the cold start injector during starter cranking) -- it should go +12V when you turn the ignition key to the "start" position. If it does -- then you'd need to look further downstream and probably check the connections/voltages at the starter itself. If it doesn't go +12V -- then you'd need to look upstream at the ignition switch and/or wiring.
    Just a suggestion as a (fairly easy) place/test to look to determine the needed direction...
  10. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    I guess the injected ones are a lot different from the carb ones if the fuel pump doesn't come on when you turn the key!
  11. tbakowsky
    Sep 18, 2002
    20,031
    The Cold North
    Tom
    One thing you will have to do is check to make sure you are getting ignition power to the starter solenoid. The car will have to be jacked up,or put on a hoist to do this. If you find that you do have power to the starter with the key turned by a helper, then more then likely the starter went south for the winter. BUT..you may want to put a 36mm socket on the crank pully and see if you can turn the engine by hand(clockwise rotation). God forbid anything happend here.
  12. Davidindallas
    Davidindallas Formula Junior
    Nov 5, 2003
    344
    Do you smell gas? I had this problem in my 86 328 once. It turned out that the cold weather choke (now an electric unit) was staying open throughout the start process flooding one bank and killing the start. It was an easy fix once it was chased down.
  13. David Coutta
    David Coutta Rookie
    Dec 20, 2004
    3
    Guys, I want to thank each and every one of you for the suggestions on my 308 problem. I have been out of pocket until today and just got into Chat this evening to check up on my problem with the 308 that will not start. I am printing off all of your suggestions and headed the shop Monday or Tuesday to get my self a little dirty running down the items you have outlined. I will be in touch next week and let you know how I do. Thank you again and a Very Happy New Year to each and every one!
    David
  14. jimangle
    jimangle F1 Rookie
    Nov 5, 2003
    2,506
    Haverford
    James
    How about trying to push start it? Is it ok to push start these cars? If so, use second gear to do it.
  15. LopeAlong
    LopeAlong Formula Junior
    Mar 29, 2004
    461
    West of St. Louis
    Jim
    David,
    Just because the battery will turn on headlights and other accessories does not mean it is healthy enough to turn over the motor. Even a jump box will not overcome some issues. Start with the obvious first (and easiest) and positively eliminate it as a cause. Get a battery tester and check the cells. If ok, check connections (remove and clean), then move on to other suggestions mentioned here. The clicking/spark noise could just be the starter solenoid gasping for juice. Good luck - let us know what you find!
    Jim
  16. LSU348
    LSU348 Formula 3
    Dec 19, 2003
    1,047
    Sugar Land
    My 85 GTB just had a similar problem - I have not gathered if your starter is turning over or not. If it is and you get no fire on either bank (no spark) check your RPM sensor. FoA could fix that in a jiffy.
  17. Steve King
    Steve King F1 Rookie
    Feb 15, 2001
    4,367
    NY
    I would believe it is in the starter circuit. Either the starter relay or the starter solenoid . If you get the loud click but the starter does not engage it is the solenoid. Should be a simple fix baring the job of getting the starter out.
