85 Ferrari Mondial air con dryer | FerrariChat
Discussion in 'Mondial' started by Anthony bentley, Nov 24, 2017.
  1. Anthony bentley
    Anthony bentley Formula Junior
    May 20, 2006
    560
    London
    Anthony Bentley
    Hi,
    There seems to be a leak from what I believe is the air con dryer black canister under the front bonnet, its seems to be from one of the hoses.
    Couple of questions
    1, is that the air con dryer?
    2, Is it a case of just replacing the hose or the whole thing?
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Assuming it is on the passenger side and it has a hex headed pressure switch with 2 wires coming out of it, then you are correct.
    Does it have solid pipes or hoses connected to it ? The drier is available as a seperate item at about £120. I cannot remember the pipe/ hose connection areangement but if a hose then you can justreplace that.
    Are you using r12 or 134 ? Oem was r 12 but converted to 134 but it needs different flexy hoses
  3. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Hi, I'm not sure which gas I presume it's the old. Do you know who supplies hoses.
    Thanks in advance.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Superperformance stock the drier, i cound not find the drawing on eurospares site but it will be there. Best to talk to a car ac charging outfir re the hose as it will be standard fittings and can be made locally.
    Look at the service history to see if it has had a 134 conversion as i think they replace the hoses that run from front to back, original hoses will not hold 134 as it leaks through the hose walls
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Look on eurospares web site, mondial page 122 under heating and cooling, drier and hoses shown as available
  6. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    Hoses go from dryer to condenser in front and from dryer to the AC unit under dashboard I believe....so no need for the hoses that are going to the back of the car.
    Guido
  7. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    Not knowing anything about air con, what is the job of the dryer?
  8. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Driers job is to dry out any moisture in the fridge gas before it goes through the expansion valve, if you had moisture in the high pressure liquid refridgerant then it would turn to ice when it went through the expansion valve and block it.
    The circuit is -: low pressure cool gas is drawn into the compressor, it is compressed as gas to say 180 psi from the 30 psi which it enters the compressor, it then goes through the condenser which is a radiator in the front nose of the car- this condenses the high pressure hot gas to a high pressure cool liquid.
    It then goes through the drier to remove any dirt or moisture, then through the expansion valve where it is changed from a high pressure cool liquid to a low pressure very cold gas- it now enters the evaporator and the car fan blows air over the evap so you get your nice cool air.
    This has the effect of heating the gas up and it returns to the compressor for another circuit.
    The pipes or hoses going to the engine compartment are the suction and discharge pipes for the compressor.
    If you change the hose, you are going to lose the gas- so it will need a full recharge using special equipment.
    With the system empty you can either renew the drier or lift the drier out and try blowing with your lips into the inlet- if you feel no resistance then it is not blocking up and you can put it in a warm oven to dry out the silica jell beads inside it, saves buying a new one.
    Expect to pay about £100 to get a gas recharge
    Think of the expansion valve as similar to way a CO2 fire extinguisher works. Cool CO2 liquid turning to cold CO2 gas as it expands out the nozzle
  9. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Is the pipe leaking on the metal part or the flexy hose section
    If that pipe is going behind the dash then it is the outlet from the drier to the expansion vavle. Have a look on Eurospares site for the system diagram
  11. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    The drawing shows a short pipe going to the bottom of the evaporator so you should see it just above the cabin floor carpet, it connects onto no 48 exp valve
  12. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
    I believe it’s the hose, it leaks onto the carpet. How do you get a spanner on the cabin end to undo it?
  13. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Looking at you pic of the pipe going through the bulkhead, it looks like you are near the end of the hose as i can see the swagging of the hose on the metal pipe. I think the union is on the other side of the bulkhead so i would try pulling the rubber grommet out of the bulk head and get a crowsfoot spanner to fit the nut on the pipe.
    You can buy crows foot spannrs as a kit, try Amazon or e bay
  14. Anthony bentley
    May 20, 2006
    560
    London
    Anthony Bentley
  15. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    I take it that pic is taken inside the car footwell, so i am seeing the pipe coming through the rubber grommet in the front compartment bulkhead. If thats the case then the pipe nut/ end of hose is in the evaporator casing.
    Have a look at the eurospares site diagram as it shows the construction of the housing
  16. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Looking at the drawing, the lower half of the split casing item 46 seems to house the evap/exp valve/the nut end of your pipe. There looks to be either some screws or clips holding the lower to the upper casing. I would assume u have to drop the lower casing to get access.
    Best of luck on that one as not an easy job
  17. porphy
    porphy Formula 3
    1,209
    LouisvilleKY/Switzld
    Randall Gatz
    I had to remove the dash to access all that I needed but this included changing the blower motor. That hose connects directly to the expansion valve and if you can gently pull on the tube you might be able to disconnect it from the expansion valve. It is tight but doable.There is a lot of very sticky insulation around those tubes in the casing and once that the insulation is removed things become clearer. New replacement insulation for the tubes is much less sticky and easier to install. The attached picture might orient you somewhat more. Image Unavailable, Please Login
