'85 Mondial Cab --air injection questions | FerrariChat
Discussion in 'Technical Q&A' started by Geoman54, Jul 8, 2007.
  1. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    Just recently I posted info about a noise that I traced to a fractured/melted plastic T on the air injection system. I suspected the "burp valves" on the two banks had worn out after 22 years and were allowing exhaust heat to reverse flow into the air-pump delivery piping. I bought two new valves and a 3/4 inch plastic T. The only valve I was able to get to this weekend was the rear one, and upon removal and blowing through it I confirmed that it was indeed shot. So after replacing the one valve, and the T -- I fired it up. All was quiet-- the noise gone, and under cold start conditions I noticed a new sound from the air cleaner cover of pressurized air. Someone mentioned that this entire system only runs for a short period of time when the engine is cold. This I confirmed as being the case on my vehicle (at least the rushing air delivery into the air cleaner cover stopped after the engine warmed).
    But-- after about a hour ride today I noticed the sound again at idle. Back in the garage with a flashlight I saw that once again -- the T had fractured -- this time on the "leg" leading to the front burp valve (Last time it was the other leg leading to the rear valve). Damn!
    Of course I'm going to now remove the access cover from behind the rear seats and change out that second burp valve,and probably try and find a metal T this time-- but I'm also wondering If I may not have another problem-- say a restriction in one or more of the actual air nozzles on the exhaust manifolds.
    When I had the engine running from cold-- I felt the pressure hose going to the rear air injection manifold and it seemed to be rather hard like it was under significant pressure. Has anyone seen a condition where the nozzles become clogged with carbon and end up not delivering anything (or very little) into the exhaust gas stream?
    Yeah-- I know - if I was in another part of the country I'd just remove the entire blasted system and install blanking plugs on the exhaust manifolds. But I don't have that option here in Northern California, as I have to make the system fully operational.
    regards,
    Geoman54
  2. 350HPMondial
    350HPMondial F1 Veteran
    5,325
    Edwardo
    Mike,
    I mentioned that the system used, is only during warm up. (I had an 85 Mondi in Colorado, , very strict smog laws in Denver.)
    You will have to take off the front distributor cap and rotor to get access to that Smog Valve. I remember using two wrences because it will be tight and the metal injection pipes flex. Squirt it with AeroKroil the day before.
    You don't have a smog pump, you have an electronic unit in the fwd drivers side of the engine compartment. Air is scavanged in by the Ferrari intake system.
    Enjoy the ride,
    Edwardo
  3. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    Edwardo,
    I take this as meaning that the actual air pump for injection is a electric compressor against the firewall on the drivers side? And this draws it's air from the hose plumbed into the air cleaner housing?
    hmmm... that being the case, I guess it is the actual air injection manifolds that the smog station verifys are in place that constitutes that part of the visual inspection for smog equipment. After a succesful smog test I could potentially disable the electric compressor, remove the injection nozzles/manifold and fit blanking plugs for the two year period in-between smog tests.
    It just seems to me that the pics I've seen on this site show the nozzles as being a major obstruction in the exhaust port. It would be interesting to know if anyone ever did a before and after dyno run to quantify the power difference.
    Even though my car is a California model, I did live in Colorado up until four years ago when I acquired this car. I never registered it there, but do remember having some trepidation regarding its ability to pass the Colorado test. Did you have any hurdles to clear with your car?
    regards,
  4. 350HPMondial
    5,325
    Edwardo
    Mike,
    My 1985 Mondial Cab. didn't have a chance in Denver, CO to pass smog.
    (It had a NOREWOOD Turbo Motore' in it and all the cats taken off.
    I had to registure it up in park, County, CO at my friends cabin.
    When I drove it to the DMV, up there in Gods country ,, ,the whole DMV and all the people came outside to see the car. (First Ferrari ever.)
    Your 1985 system is pretty cool, it doesn't really rob HP at all.
    The smog nozzles are really hard to get out, I would leave them and the whole system in place. You have USA collectors not exhaust headers. (bummer)
    Or, buy a set of Euro headers and a NON-cat system.
    Pull your engine each two years for that smog check. (Mondial Motore' are the easiest to pull.)
    (And, yes you can just unplug the little pulse injection system in the engine bay. But, why,,,,,,,,,, it only comes on for 5 minutes.)
    Edwardo
  5. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    Edwardo,
    A few years before I made the trade deal with my brother-in-law that handed me the Mondial Cab, and him -- my March 832 F2 car -- he had a new twin turbo kit for the car. Then, with a momentary lapse of reason he sold it about a year before our deal. Oh well!
    The only complaint I have with the stock configuration is that it needs about 50-100 more HP. How much boost were you running, and what model/make turbo's?
    I do have two Faegol roots-style superchargers, and have "bench-raced" with the idea of fitting one with about 7lbs. of boost -- in the physical location now occupied by the stock intake plenum, retaining the CIS injection and moving onto a Electramotive ignition. But then ya gotta fit a more efficient exhaust from the exhaust ports down, upgrade the braking system, lower the car with new coil-overs,etc.
    Put a roll-bar in it made of airfoil shaped tubing, fit a pair of the Sparco Milano tan leather seats, pull out the back ones and have the upholstery shop fabricate a nice leather deck with a couple of storage compartments in it............
    Yeah -- thats the dream down the road.....for now I'm just having a blast driving it with top down and carving corners.
    regards,
  6. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    on my '89 328, the T is metal. GT car parts (623-780-2200) made up a batch of them - part number 109887 for $35, which seems somewhat absurd until you get prices from some other places...then your inclination is to buy a spare :)
    if you got enough exhaust gases in to rot the 3-way union, the white-domed vacuum-actuated check valve (121751) may leak a little too. May be worth doing the blow-thru test on.
  7. 350HPMondial
    5,325
    Edwardo
    Mike,
    twin turbo.....! Love to see that on my Mondial-8...
    Check out,,
    www.norwoodperformance.com
    at 7 PSI, my 1985 QV Motore' would put out 350 HP at the rear wheels. The engine would spool up so quick in second gear that, lucky for Guido, he had put third on the same shaft.. (I seem to recall third gear was way over, , "I wanna die" speed anyway.) (wink) I used to pull the hill from Denver to Chief Hosa at way over 100 MPH... That hill goes straight up too.. In real thin air.
    sold the car, , (sniff)
    bought another home.. (smile)
    What is a march 832 f2 car???
    How much are they worth?
    Edwardo
  8. 350HPMondial
    5,325
    Edwardo
    #8 350HPMondial, Jul 11, 2007
  9. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    #9 Geoman54, Jul 11, 2007
    Edwardo,
    I remember that grade you are talking about. That's one thing I do miss about Colorado --- all the open space in the mountains to really enjoy this type of car. The population density here in Northern California makes it a bit more of a challenge to find a place to open it up.
    Thanks for the pic of your engine compartment. So-- I gather this was not a intercooled set-up (usually not required at 7 psi) --- and turbo technology was more in the infant stage back in the 80's anyway. Just look at what these kids are doing now with off the shelf stuff (my Son included who has a 425 h.p. Toyota Supra --- yikes!)
    I valued the March F2 car at $35K --- with the Cosworth BDD in a box (not the original motor which was a 320 hp BMW injected 2-litre). So he gave me $5K and the Mondial in trade. He had bought a 1987 Straman TR, and the Mondial had turned into a garage queen. I'm in the process now of doing a lot of little things to make it as reliable as it should be. Having a blast.
    Attached pics of my Mondial, and two of the Straman.
    regards,
    Mike M.
  10. snj5
    snj5 F1 World Champ
    Feb 22, 2003
    10,213
    San Antonio
    Russ Turner
    Beautiful car.
    Let me know if you ever want to sell the HRE wheels.
    best
    rt
  11. Geoman54
    Geoman54 Karting
    Jun 12, 2007
    50
    Northern California
    Michael McLaughlin
    Edwardo,
    The March was constructed by the factory in England for the 1983 European Formula 2 season. It was customary that these drivers -- if talented enough and with some sponsership behind them-- would move into Formula 1 the next season. My car was re-homologated after the season ended -- sent down to Australia and fitted with a Cosworth BDA (about 100 hp down from the BMW 2 litre output of 320 hp). It weighs about 1000 lbs, and is a "ground effects" car with tunnels each sise of the main cockpit. I'll try a dig up a picture of it.
    regards,
