85 Mondial QV Cab Headlight Relay Problems | FerrariChat
Discussion in 'Mondial' started by jagjet, Nov 19, 2007.
  1. jagjet
    jagjet Rookie
    Oct 24, 2007
    31
    Florida
    W.Robert Phelps, III
    Here it is I have a hot relay 101 for the Headlight doors that stays hot. To the Touch very Hot! I remove 12 volt in on Term. # 86 and It cools and battery doesn't discharge. 5 terminals on the relay 2 are green and 3 are red. Red all have 12 volts (battery). It doesn't match any diag I have but I could use a QV 82-85 Diagram if someone is willing to share a .pfd of the file.
    My knowledge of the wiring is not bad if I have the chart and the correct markings. If you know what voltages go to what terminal on the relay that could be a great start.
    Also when I removed power from the relay the lights opened uncommanded. So I'm guessing somebody has done a poor work around and left me no clues!
    Always willing to share What I have learned and have been Restoring Jagaurs for 37 years and Ferraris for about 20.
    Your thoughts! Tells me If you need more info about the Problem
    Cheers
    Robert
    Tried contacting Ferrari-Uk and couldn't even see a parts page for a wiring Chart
  2. Verell
    Verell F1 Veteran
    May 5, 2001
    7,022
    Groton, MA
    Verell Boaen
    Looks like Ferrari.uk has an '84 WD in stock:
    106 95990832 MONDIAL QV 1984 USA WIRING DIA £12.15
    Suspect there wasn't an '85 WD, as that's what I was searching for.
    You just gotta know how to search:
    Went to ferrari.uk, selected [advanced search], then selected [mondial], [other] & keyword 'wiring'.
