'85 Mondial QV Cylinder Head Resurfacing | FerrariChat
Discussion in 'Mondial' started by sarkees, Feb 8, 2024.
  1. sarkees
    sarkees Karting
    Jun 12, 2023
    61
    Virginia
    Steve Sarkees
    Hello Everyone.
    Not long ago I had bend valves on one of my heads. (was determined that a spark plug broke apart) I have everything torn down and and I purchased very expensive Valves, guides, springs, etc... I have a machinist who is pretty well know in my area for high performance and race builds. He needs information on how much can be taken off the surface. Does anyone know where I can find that info?
    Much appreciated.
  2. afterburner
    afterburner F1 Rookie
    3,470
    Switzerland
    Urs STEMMLER
    Sorry to hear that...
  3. sarkees
    sarkees Karting
    Jun 12, 2023
    61
    Virginia
    Steve Sarkees
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
    Just take off the minimum to get a good sealing surface and no more.
    Rifledriver likes this.
  5. Rifledriver
    37,090
    Some machinists like to take off enough it looks like a brand new head so it looks pretty. That is generally not required.
  6. 19633500GT
    19633500GT F1 World Champ
    13,082
    Blueberry
    Muffin-Tops
    They call it "skimming" for a reason :)
  7. sarkees
    sarkees Karting
    Jun 12, 2023
    61
    Virginia
    Steve Sarkees
    yep - problem is (I should have mentioned) one of the heads was fuzed to the block studs. Rope trick got it up a little. Took 3 weeks of slowly using a wedge on each side (along with heat and lubricant) to raise it up enough to fit a brake spanner on each side. So - it's scared up a little. He is going to use pin weds on the scars and then shave. It was bear. Wedging sure beat cutting the head off. a used head is $2900.
  8. Renren
    Renren Rookie
    Aug 18, 2022
    7
    France
    Renaud
    My machinist took respectively 0.08mm and 0.10mm on mines (QV also, and sorry for the metric, I'm french). But fortunately for me, they we're not fuzed with the studs.
    Just ask him to grind the minimum.
    sarkees likes this.
  9. sarkees
    sarkees Karting
    Jun 12, 2023
    61
    Virginia
    Steve Sarkees
    Thanks for the info!
