85 mondial QV running but very rich and... | FerrariChat
Discussion in 'Technical Q&A' started by culo951, Apr 24, 2010.
  1. culo951
    culo951 Karting
    Apr 24, 2010
    97
    Pataskala, Ohio
    Adam Culp
    With some great advise I was able to get the mondial running, but not untill after bypassing the secondary fuel pump sensor with a jumper wire. Now that it is running it is running very rich. Does anyone have any ideas on what is causing the secondary relay to not work? I have tried other relays with no success. Could it be the fuse block itself? Are the fuse block and PCB separate?
  2. culo951
    culo951 Karting
    Apr 24, 2010
    97
    Pataskala, Ohio
    Adam Culp
    I pulled the fuse/relay panel completely out of the car and went through it. It apparently had a bad connection and i was able to repair it.
  3. darthenzo
    darthenzo Formula Junior
    Dec 8, 2007
    488
    Glendale, Arizona
    James
    Isn't it great when you answer your own question? Just be carefull you don't start arguing with yourself, I. get weird looks when I do that.
  4. culo951
    culo951 Karting
    Apr 24, 2010
    97
    Pataskala, Ohio
    Adam Culp
    #4 culo951, Apr 25, 2010
    Ha ha, thanks, it is a nice feeling. I have always been told that you can talk to yourself as long as you don't start answering yourself!! I am so glad I found this site, it has been so helpful and everyone seems to appreciate what this is about, having the greatest car in the world and helping eachother out!
