'85 power problem-one bank | FerrariChat
Discussion in 'Boxers/TR/M' started by 1974gt4, Jul 17, 2015.
  1. 1974gt4
    1974gt4 Formula 3
    Sep 19, 2009
    1,504
    in my garage...
    Dr. Italiani
    Gents,
    One bank of cylinders stops running when the engine gets hot. After a few cycles of the rad fans.
    I have done no diagnostic, just symptoms to relate.
    Cold? Runs fine, and at normal operating temps, good, park it for lunch and something is getting heat soaked and not working…
    Ideas please. and Rifledriver moved … :(
    Grazie Mille.
  2. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,071
    Troy, Michigan
    James
    fuel pump relay connections in the fuse panel up front good?
  3. 1974gt4
    1974gt4 Formula 3
    Sep 19, 2009
    1,504
    in my garage...
    Dr. Italiani
    Great suspect…
    Will check, It might be that but seems ambient temp related.
    Thank you for weighing in.
    Cheers.
  4. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    My first place to check wold be the fuse box white connectors.
    While you mention ambient, don't forget that a bad connection in the fuse box will have its own "ambient".
    As soon as the circuit board gets too hot it will limit conductivity and give you the problem, once cool and the connection solder set it with start to work again.
    This is a common fault with many Ferraris of that age.
    Any way thats where I would start and after that I would check the fuel pump to the faulty bank.
    HTH
    P
  5. Shamile
    Shamile F1 Veteran
    Dec 31, 2002
    6,712
    Lakeland FL
    Shamile
    I agree with the above...check the fuse box first. I would check the fuel pump relays as they do get hot. A little trick is to pull each fuel pump relay and bend the tabs slightly outwards and stick them back in. The heat transfers to the board and the plastic holding the receiver pins gets slightly warped.
    Shamile
    Freeze. ..Miami Vice!
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  6. 1974gt4
    1974gt4 Formula 3
    Sep 19, 2009
    1,504
    in my garage...
    Dr. Italiani
    Gents,
    Sounds like a viable plan.
    I will slightly bent the connectors to increase surface area and look for signs/evidence of heat there.
    Grazie Mille.
  7. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    FIRST Vhave a look at the white connectors at the FB please :)
  8. 1974gt4
    1974gt4 Formula 3
    Sep 19, 2009
    1,504
    in my garage...
    Dr. Italiani
    So noted.
    Again, grazie mille.
