85 QV starting problem | FerrariChat
Discussion in '308/328' started by Peter308, May 9, 2010.
  1. Peter308
    Peter308 Rookie
    Aug 24, 2009
    21
    Hertfordshire, UK
    Peter Wright
    Any advice greatly received!
    I went for a drive today but the car would not start. the battery is fine and the starter motor is working fine but the engine just will not fire up. My car is a Euro model GTB and had a full service 6 months (1500 miles) ago. I tried bump starting it in reverse and first but this made no difference. I drive my 308 fairly regularly; last time out was a couple of weeks ago. Never had any problems before, it has always started first time.
    Any ideas where to start diagnosing the problem guys?
    Peter
  2. Birdman
    Birdman F1 Veteran
    Jun 20, 2003
    6,689
    North shore, MA
    THE Birdman
    Start with the basics. Pull a spark plug. Is it wet? (i.e. getting fuel). Is there a spark when you crank it? The car just needs fuel, air and spark (at the right time) to run. One of those three is missing and it's not likely to be air. So that narrows it to two.
    Birdman
  3. Peter308
    Peter308 Rookie
    Aug 24, 2009
    21
    Hertfordshire, UK
    Peter Wright
    Birdman,
    Thanks for the advice. I checked plugs (looked good) then wondered why I could not smell fuel so checked the relay and fuse for the fuel pump. Guess what, the 16A fuel pump fuse had corroded/blown finally, so switched another 16A fuse and she fired up straight away! I don't have a spare 16A fuse so I now have an 8A fuse for the heater - guess if the load is too big it will just blow. Clearly time to switch to your fuse block!!
    Peter
  4. culo951
    culo951 Karting
    Apr 24, 2010
    97
    Pataskala, Ohio
    Adam Culp
    Isn't it great when it's easy! I had the same problem afew weeks ago with my 85 mondial only it was a relay issue!
  5. jeffQV
    jeffQV F1 Rookie
    Feb 13, 2004
    2,976
    NZ
    jeff
    Same here, getting a 'cheap' fix on Thursday saving up for the biggie replacement fuseboard!
