85 QV Starts, when it wants to | FerrariChat
Discussion in '308/328' started by whiskeyps, Nov 18, 2016.
  1. whiskeyps
    whiskeyps Rookie
    Oct 28, 2014
    42
    Nor Cal Bay Area
    Paul
    I've had my QV for about a year now and its been running fine. About a month ago I tried to start it and it felt like not enough juice coming from the Battery to get it turning - jumped and no problem. Just tried again today and the battery was fine - turned the key and starter wouldn't turn. Tried to jump it and still nothing from the starter (You can hear it delivering juice but nothing is turning). Considered a push start but since I was by myself I thought that was probably not a good idea. Battery checks OK and I wouldn't be surprised if it started tomorrow, but any suggestions would be much appreciated.
  2. miketuason
    miketuason F1 World Champ
    Feb 24, 2006
    15,842
    Cerritos, CA.
    When you say nothing from the starter, not even a clicka?
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    6,016
    Isle of man- uk
    Get a multi meter and connect up a wire to measure the solenoid output, if that is ok then check the starter terminal for voltage. Not sure what you mean by being able to hear the juice being delivered ?
    Is the car fitted with the extra starter motor relay kit ?
    You need to know if you are getting power to both the solenoid and the starter
  4. ferrariowner
    ferrariowner Formula 3
    Feb 21, 2014
    1,155
    Mansfield, TX
    Ron
    My 85 QV starter required rebuilding about a year ago. Same symptoms. Make all electrical checks first. I took it to a starter/generator repair shop. It cost less than $75. The drive gears had frozen and wouldn't turn. I noticed it spins much faster after the rebuild.
  5. whiskeyps
    whiskeyps Rookie
    Oct 28, 2014
    42
    Nor Cal Bay Area
    Paul
    Thanks, will check power to both.
