86 328 won't start | Page 2 | FerrariChat
86 328 won't start
Discussion in 'Technical Q&A' started by LUCH, Jul 11, 2010.
  1. LUCH
    LUCH Rookie
    Nov 26, 2003
    30
    Massachusetts
    Karl
    Well I put the car back together and I didn't run. So I started searching further and found the connector that plugs into the fuse and relay board on the dash had one pin the was discolored and the prongs were spread out. I removed it and closed the contacts and now everything seems to be fine. Went for a test ride and no problem. What a pain. I guess when I was checking the key function relay I must have moved that connector which made contact and allowed the car to start momentarily earlier in the week. I guess that's what led me to look there today and ultimately find the bad connector. Well hopefully the problem is solved.
    That's why this site is so good.
    Thanks everybody for your help in this matter.
    Karl
