86 Mondial 3.2 - buzzing noise related to oil pressure? | FerrariChat
Discussion in 'Mondial' started by Shortsha12, Jul 2, 2023.
  1. Shortsha12
    Shortsha12 Rookie
    Jul 18, 2022
    5
    Shawn Short
    Loud buzzing noise starts 15 seconds after cold start as oil pressure increases. Seems to gradually fade as engine warms up.
    appears loudest at the two braised oil hoses on drivers side.
    what is causing this buzzing noise? Doesn’t not seem to be the oil type.
  2. Jeka
    Jeka Formula 3
    1,182
    Rotterdam
    Johan
    Maybe one of the two hoses is sitting against the inner wheel arch which amplifies the noise?
  3. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Sounds like the oil pressure relief valve is lifting, but you normally cannot hear it, might be an idea to have a look at it.
  4. theunissenguido
    theunissenguido F1 Rookie
    Jan 21, 2004
    2,674
    Argent/Brasil
    Guido
    What sound when accelerating engine ? Does it stay the same or its gets louder ? I'm thinking it can be the intermediate gear bearings.
  5. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    The oil relief valve will lift when cold, the fact it stops when the engine warms up makes sense as the oil is getting warmer
  6. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,962
    Isle of man- uk
    Any progress ?
