86 mondial thermostat switch | FerrariChat
Discussion in 'Mondial' started by ddiggler, Jul 3, 2021.
  1. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
    Fans weren't working. Connected the two wires together and turned on the ignition. They started working. From what I gave learned from here is that the switch is bad. Two questions. Does anyone know of an aftermarket switch? And also, can I leave them constantly on until I replace the switch? Any input is greatly appreciated. Thanks. Doug.
  2. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
    Look on superperformance uk web site, listing radiator fan switch. 168008. 24610155. @£25
    Where are u located
  3. LA_Rari_22
    LA_Rari_22 Karting
    Nov 3, 2019
    52
    Len U
    HI... had the same problem. What I did was solder a wire to each wire and run those 2 wires into your cabin connected to a toggle switch. Now you have a bypass and can turn on and off the fans, even after you have replaced the coolant temp sensor. The fans auto kick in at 195 degrees, and if heavy traffic is expected sometimes turning them on ahead of time with the new bypass switch comes in handy. good luck!
    there's also a aftermarket coolant temp switch that kicks on the fans earlier than 195, but I just got the OEM original as a replacement. Someone here has that part number for that switch (might do that one day). Hope this helps!
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
    Also shown in stock at eurospares uk
  5. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
    Washington state. I will check out the website. Thank you for the part numbers.
  6. ddiggler
    ddiggler Karting
    Nov 24, 2017
    77
    doug nelson
    I haven't looked yet but where did you run the wires through to the cabin at?
  7. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
    Thats over the water then, but a rowing boat and save on shipping. Its summer so will be a bit quicker
  8. 328tobe
    328tobe Karting
    Apr 7, 2012
    64
    Northern VA
    Luuda
  9. LA_Rari_22
    LA_Rari_22 Karting
    Nov 3, 2019
    52
    Len U
    You can mount the toggle switch anywhere you like, be creative. You can start by removing the plastic cover surrounding the brake fluid reservoir in the frunk and find an opening near the footwell.
  10. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,960
    Isle of man- uk
  11. moysiuan
    moysiuan F1 Rookie
    4,186
    Canada
    This switch is identical to stock. The black plastic pieces thar protect the connection tabs are not on the uk sourced item. In both cases, these connections are not as waterproof as they should be, there really should be a rubber boot over the connectors. Make sure you smear some dielectric grease on this so you get some water resistance.
