86 Testarossa won't start | FerrariChat
Discussion in 'Technical Q&A' started by backyardmechanic, Oct 25, 2016.
  1. backyardmechanic
    Oct 24, 2016
    3
    Changed spark plugs, rotors, 2 distributor caps. Car has spark turns over, but it won't start. Any suggestions.
  2. Mantinger
    Mantinger Karting
    Jul 30, 2004
    145
    Netherlands, Drenthe
    H
    Try to spray brake cleaning fluid or starter fluid into the inlet manifold. If it starts there is a fuel delivery problem. Can be pump related; pump not running.
  3. backyardmechanic
    Oct 24, 2016
    3
    Where is this inlet located.
  4. mike32
    mike32 F1 Veteran
    May 13, 2016
    5,983
    Isle of man- uk
    Try into the air filter intake,
  5. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    How long since it ran last? Check the fuel pump connectors at the fuse panel.
  6. afwrench
    afwrench Formula Junior
    Nov 24, 2004
    593
    NY
    Hi Frank, dont go chasing ghosts.Was the car running prior to the plugs and cap change? If so, look to what you fiddled with.Otherwise a shot of ether will tell if it is lack of fuel.Go step by step. Not to be unkind ,but if you do not know where the air goes in you should probably study up on the car prior to digging into the motor in even the smallest way. Good luck,Mike
