86 TR - brake lights constant on | FerrariChat
Discussion in 'Boxers/TR/M' started by Jbak, Oct 25, 2023.
  1. Jbak
    Jbak Rookie
    Feb 24, 2022
    32
    Good morning,
    When I was warming up the car yesterday I noticed that all three brake lights were constant on. Car drives fine, but brake lights stay on regardless of pedal or hand brake are engaged.
    I searched the forum and found a thread where the lights wouldn’t turn on, but that’s not the case as the switch is providing constant power to the red brake wire.
    Any advice? Easy fix or better off taking to dealer?
    Thanks in advance,
    Joe
  2. Rifledriver
    37,089
    Unplug switch and see what happens. Probably a stuck switch.
  3. Jbak
    Jbak Rookie
    Feb 24, 2022
    32
    When I unplug the red wire from the switch the brake lights turn off.
  4. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,525
    romano schwabel
    then you need a new switch
  5. Rifledriver
    37,089
    There is your answer.
  6. Jbak
    Jbak Rookie
    Feb 24, 2022
    32
    Thank you!!
    For replacement, can I do all from up top under the hood or must I access from driver side footwell?
  7. Steve Magnusson
    26,785
    #7 Steve Magnusson, Oct 25, 2023
    It might be doable from the top -- i.e., unplug the wires, loosen the jam nut, unscrew the switch. I can't recall if there is another nut on the footwell side -- but you should be able to have a look and see.
  8. Jbak
    Jbak Rookie
    Feb 24, 2022
    32
    Thank you all! I have a new switch arriving Friday. I’ll post photos of replacement if I’m successful.
    turbo-joe likes this.
  9. ago car nut
    ago car nut F1 Veteran
    5,495
    Madison Ohio
    David A.
    I believe it can be replaced from above!
