86 TR driver's window regulator cable routing diagram | FerrariChat
Discussion in 'Boxers/TR/M' started by fast911ray, May 20, 2019.
  1. fast911ray
    fast911ray Rookie
    Jun 20, 2011
    15
    Sarasota, Florida
    Raymond Banicki
    HELP! A friend's TR driver's window became very slugglish, so he took it upon himself to pull the motor for a peek inside. As expected, he could'nt remember how it came apart., and now I'm sitting here with a tangled, unwound cable and dangling motor. Does anyone knoow of, or have a routing diagram/ or step by step assembly procedure available?
  2. fast911ray
    fast911ray Rookie
    Jun 20, 2011
    15
    Sarasota, Florida
    Raymond Banicki
  3. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    8,929
    romano schwabel
    good luck when you not put it out ;)
    when you never did this before then best would be to open the passenger door and look how it has to be. otherwise if you use a little logic you find out how it has to be. it is no magic.
    unfortunatley I have no pictures but I did it already several times
    fast911ray likes this.
  4. Prova85
    Prova85 Formula 3
    Nov 13, 2003
    1,993
    So. Shore MA.
    Kenny K
    Routing diagram is shown fairly well in the parts manual for the door. Google is your friend if you don't have the manual. But that won't help you much with getting it properly spooled at the motor.
  5. rpissm
    rpissm Formula 3
    Aug 11, 2013
    1,620
    Salt Lake City, UT
    Joe
    There's a whole thread on window cable routing / rewinding. Feel free to search. I contributed to it, so search for my screen name.
    Sent from my Moto Z2 Play using Tapatalk
  6. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    Here's a corrected diagram for the drivers side--the one in the Workshop Manual is incorrect (it shows the circled area reversed). Good luck!
    fast911ray and ozziindaus like this.
  7. turbo-joe
    Apr 6, 2008
    8,929
    romano schwabel
    this tim what you marked with a red circle is very important. otherwise it will not work
  8. ozziindaus
    ozziindaus F1 Veteran
    9,799
    Detroit
    Sam
