86 TR Engine Out items to look at or address? | FerrariChat
Discussion in 'Boxers/TR/M' started by ItalianOne, Nov 10, 2021.
  1. ItalianOne
    ItalianOne Formula Junior Rossa Subscribed
    May 21, 2008
    619
    Mich
    Kevin R
    The car is in for its full engine out belt service. The car has 32k miles on it, is there any other items I should address that am not thinking about while the car is being serviced?
    This was my list of items maybe to address below.
    Rear Differential replacement - I have reached out to Newman to see if he is doing another run, hopefully (YES).
    If not what's a good backup supplier?
    Stock twin disk clutch replaced- Any recommendation on clutch replacements?
    Trans Axle weak? -Heard about this issue, should this be addressed? any recommendations on replacements?
    Fuse Box - Have reached out to Guido regarding a replacement, looking at feedback or other fuse box replacement advice.
    Pump chain and water chain replacement? - First time I heard about this issue was on a you tube car review. Never read about it on the board. Is this a issue that should be addressed?
    Any other items you guys recommend?
    Do appreciate any advice or recommendations in advance.
  2. turbo-joe
    turbo-joe F1 Veteran
    Apr 6, 2008
    9,546
    romano schwabel
    MODENA in australia
    keep the 2 discs clutch
    so little mileage? I think no need to do some
    wait for guido´s answer or take out the relays with the most amp ( radiator fans, fuel pumps, ac radiator fan ) and put them somewhere outside the fuse box
    what year is your car?
    replace all seals, also from the clutch
    qwazipsycho likes this.
  3. Grease Donkey
    Grease Donkey Karting
    Jul 5, 2018
    120
    Zurich, Switzerland
    Injectors: convert to brass version Bosch replacements
    Fuel pumps: use Bosch replacements
    Water cooling fans: Spal replacements
    Hill engineering tensioner bearing
    Brake hoses
    Distribution caps etc
    Coolant lines
    Fuel lines
    Most of these parts are standard and not very costly....
  4. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Always remember to replace the exhaust check valves with new. They are cheap GM parts and will protect your air pump from severe damage. The pumps are NLA.
  5. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Do you not like the conversion kit to a single plate 512 clutch?
  6. qwazipsycho
    qwazipsycho Formula 3
    Oct 30, 2004
    1,176
    Utah
    Scott
    Replace the diff
    Replace the clutch as is
    Trans Axle's aren't weak. They are designed to break the quill shaft so you don't damage the gear box. If you upgrade your quill shaft you better beef up the gearbox.
    Do the fusebox and relocate the high amp stuff
    Pump chain and water chain replacement?? What?? No. Leave it alone.
    Yes, do the check valves.
    Yes do the seals.
    Then go drive it like you stole it.
  7. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Consider checking the water pump also. You're there so why not.
    qwazipsycho and turbo-joe like this.
  8. Natkingcolebasket69
    Natkingcolebasket69 F1 World Champ
    Jul 2, 2017
    10,231
    Miami and Bay Area
    I did my major just now and my mechanic said like Romano, I didn’t upgrade to 512 either
  9. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    I think F knew why they put in a double clutch, so why you like to change? in my competition I put in again a double clutch because of the torque I have.
  10. Steve Magnusson
    Steve Magnusson Two Time F1 World Champ Lifetime Rossa
    26,840
    Lubricate the acc cable at the engine end (best for getting the lubricant to flow down to the 90 deg bend where it's needed most).
    vincenzo likes this.
  11. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,824
    Bologna
    In addition:
    Replace the fuel tank vent hoses on the firewall, they are petrified by now and are a fire hazard.
    Radiator fans and fuel pumps would be good to replace (helps your fuse box), along with the big diameter fuel hose which connects the left and right side tanks.
    Replace your rad hoses and thermostats. Look for leaks at the thermostat case.
    I just replaced my differential (thanks Newman) and oil pump chain and tensioner after 58,000 km on my 91 TR (all parts looked good but it was worth the peace of mind). Shimming the differential to get the right pattern and drag, is, uh, educational, if you are doing it yourself.
    When you replace your differential seals, the part number in the parts book or on the Eurospares site is wrong. The left and right side seal part numbers are different - if you use the suggested part numbers one side will leak gear oil.
    Replace the seal on your shift shaft - the original part is an O ring, but they sill leak inside the bellows. Superformance sells a seal with a lip which you can install in the outer transmission case which will stop the drip.
    When you reassemble it, use Evans NPG in place of water based coolant, your cylinder liners and water pump seal will thank you.
    Install you cam box gaskets dry, except in the corners where they meet other parts at a 90 degree angle.
    Enjoy. I am off to finish the major on mine tomorrow.
    rbryson and Turbopanzer like this.
  12. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    good that you made in rigth john :) but even for those doing it already several times it is still always educational. never will match at the frist time.
    it depends what kind of gaskets you use. there are gaskets without silicone on and also gaskets with silicone. for the first would be good to use also some fluid gasket material. important is for both a little silicone sealing at the corners, but not too much as some are doing.
    so tomorrow finish with all and you will make testdrive or finished with engine and then put the machine in the car again? then test drive 2 days later ;)
  13. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Why?
    The 512 clutch was a Ferrari redesign to handle the increased HP loads, provide better tactile response to the driver and more quickly & decisively engage/ disengage.
  14. Natkingcolebasket69
    Jul 2, 2017
    10,231
    Miami and Bay Area
    But the TR is 10% less powerful
  15. JohnMH
    JohnMH Formula 3
    Jan 28, 2004
    1,824
    Bologna
    No, I am just finishing the engine on the table (installing the water pump seal, new clutch, flywheel, timing belts and checking the valve clearances). Maybe it goes back in the car next weekend. I miss driving it.
  16. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    wish you good luck all will go fine john
  17. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Take your time. It will be worth the extra wait. Guy's have offered some solid advice. Make it more enjoyable when you don't have to do work over because you got impatient.
    Best wishes for a great finish up!
  18. ItalianOne
    May 21, 2008
    619
    Mich
    Kevin R
  19. Veedub00
    Veedub00 F1 Veteran Owner Silver Subscribed
    Jun 30, 2006
    5,071
    Troy, Michigan
    James
    Wow! Good thing you did the right thing.
  20. Veedub00
    Jun 30, 2006
    5,071
    Troy, Michigan
    James
    Amazing.
  21. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    hopefully you may use an aftermarket diff?
  22. vincenzo
    vincenzo F1 Rookie
    Nov 2, 2003
    3,373
    Yes - the welded area is prone to failure. That said, I’ll go out on a limb.
    The weld does not look bad to my eye.
    Little/no splatter, no undercutting, no pitting, no porosity.
    I suspect that these failures are a metallurgical compatibility and/or too high a stress level issue rather than bad welds. Just due to the contour changes, the stress levels are concentrated at the outer edge of the weld.
    Likely we’ll never know for sure.
    Rifledriver likes this.
  23. turbo-joe
    Apr 6, 2008
    9,546
    romano schwabel
    until now I never have seen a broken welding, only where the welding comes in contact with the to weld material on both sides
  24. Rifledriver
    37,116
    That is how good welds fail. The actual weld, if done properly is stronger that the material around it.
    turbo-joe and MaseratiMike like this.
  25. garybobileff
    garybobileff Formula 3 Sponsor
    Feb 5, 2004
    1,180
    San Diego CA
    Gary
    This would be a great time to replace both water thermostats, possibly remove and rod the radiators while access is easy. Also check/ replace the fuel tank transfer hoses, if they aren't white stripe style or show signs of bloating.
    Gary Bobileff
    JohnMH likes this.
