‘86 TR Front Wheel Bearing cleaning | FerrariChat
Discussion in 'Boxers/TR/M' started by Veedub00, Mar 16, 2025.
  1. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
  2. Steve Magnusson
    26,794
    Don't think that you necessarily have to take off the outside bolts (but lugging the brake disc around maybe isn't handy), but you do need to remove the big nut. There are two rows of balls, and you've only cleaned one of the rows -- see the cross-sectional drawing on page F7 of the TR WSM.
    turbo-joe likes this.
  3. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    Ok. Thanks. That’s what I was looking for.
  4. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    266
    Southern Florida
    James, also look at page F13 of the Testarossa Workshop Manual. It provides the steps for "replacing front bearings," so you don't need to follow all of the steps just for repacking. When I regreased mine, I looked at same for guidance BUT because I did not want to mess with the seal, I only exposed the second row of bearings just enough to allow a complete cleaning but not enough to disturb the seal underneath or remove the lower row of ball bearings. EDoug
    Veedub00 likes this.
  5. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    Thanks, I think I am just going to do what you did.
  6. Rifledriver
    37,098
    If the bearing is removed from the hub of the rotor the inner row of balls can be removed, the bearing separator can be removed then the outer row can be removed and the races cleaned. The seal is crimped in place and cannot be removed.
  7. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    Ok, follow up question. Do I get access to the hidden ball bearings by hitting the bearing through the 2 access holes inside the splined hub so the bearings poke out? Or am I missing something? Then press the bearing back into place once I cleaned it? Or is there a way to pull out the balls without doing that?
  8. Steve Magnusson
    26,794
    Yes, I believe so. On the later 5-lug design, they made those access holes perpendicular to the inner race faces IIRC -- so those angled holes on your single-lug design seem more iffy.
  9. EDoug
    Apr 19, 2005
    266
    Southern Florida
    James, yes you got it and are not missing something (at least on my 1986 Testarossa). Tap tap tap and then alternate to the second hole and tap tap tap, rinse and repeat, until the outer row fall out with its race and be READY to catch it all. Then lift out the plastic cage exposing the second row. Below are a few pics to give you some encouragement. As I previously said, I stopped tapping once the second row was exposed just enough to allow me to completely clean it out. Others may keep tapping to completely remove the second row. EDoug
  10. Veedub00
    Veedub00 F1 Veteran
    Jun 30, 2006
    5,069
    Troy, Michigan
    James
    oh great pics, thanks so much! Normally I just go for broke, but am super cautious since I don't feel like paying for a new bearing.
  11. jgmblair
    jgmblair Formula Junior
    813
    Winnipeg, MB Canada
    Jeff Blair
    I hear the eggs that were in that crate are almost as expensive as a new bearing ;)
    moysiuan likes this.
