86 tr speaker replasment | FerrariChat
Discussion in 'Boxers/TR/M' started by ria, Nov 23, 2009.
  1. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    anyone know how to remove and replase the front speakers 86 tr? thanks.
  2. Jeff Pintler
    Jeff Pintler Formula Junior
    Jul 20, 2005
    537
    Richland
    Jeff Pintler
    There are fiberglass pods in both footwells. By carefully pulling off the weather seal in the door opening, you will find small screws into the metal wheel liner. There are also screws in the section of the speaker pod that wraps around the wheel well that is close to the trunk or firewall. Maybe two or three screws on each side. Good luck.
    Jeff Pintler
    89 348tb, 86tr
  3. Jagbuff
    Jagbuff Formula 3
    Jan 13, 2004
    2,267
    Site of US F1 Race!
    Franck
    How do you remove the tweeters... Does the dash have to come out if your car has the knee bolsters?
  4. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Tweeters are a pain in the ass.. The dash has to come out.. I would just re-use them or place tweeters on speaker panels.. Factory tweeters are pretty good.. You can get replacement grilles as well just in case they got scuffed up...
    R
  5. Joe_CT
    Joe_CT Formula 3
    May 16, 2007
    1,720
    CT
    Joe
    #5 Joe_CT, Nov 24, 2009
    The dash does not need to come out to replace the tweeters. I just removed mine today. All you need to do is remove the under dash cover and reach up under the passenger side footwell and pop it out (they just fit snug... there are no clips). The drivers side is just a little tougher. I could not reach up there as something was blocking the path, so I took a door panel removing tool, put a towel behind it and gently pryed / popped the speaker out.
    The kick panel speakers come out as described above.
    Good luck.
  6. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Factory ones are bolted in... or at least on mine..
  7. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    jeff thanks for the info. jeff do you know the size of the speakers? + what set of speakers will be a good set up for the front footwells? thanks.
  8. Joe_CT
    Joe_CT Formula 3
    May 16, 2007
    1,720
    CT
    Joe
    For what its worth, I am replacing all of my components with Focal as I did in my 308. The sound / quality can't be beat.
  9. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    ok. moore info?
  10. Joe_CT
    Joe_CT Formula 3
    May 16, 2007
    1,720
    CT
    Joe
    #10 Joe_CT, Nov 24, 2009
    Check out their website for more info. I am putting the Polyglass 6.5" Coax Speaker in the footwells.
    http://www.focal-america.com/
  11. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    i did remove the fiberglass cover on the footwells and in side is the OEM FERRARI speaker + a smoll box. this is what is on it (ferrari car speaker parts) (ref 61644000) (POTENZA MAX:100W) (POTENZA RMS:50 W) (IMPEDENZA: 4 OHM) what is this? is the a amp for the speakers?
  12. Steve Magnusson
    25,141
    #12 Steve Magnusson, Nov 28, 2009
  13. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    steve what is the purpose of this filter do you know? will be replasing the speakers. the wires go to this filter first and then to the speakers will the new speakers loose power with this filter in there? the sound on the OEM speakers are not of quality. i will use the (infinity refrence 6022i)
  14. Steve Magnusson
    25,141
    No, not really -- but I would tend towards leaving them out too.
  15. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    use it with the speakers or bypass this filter and wire direct to speakers?
  16. snowblindfriend
    snowblindfriend Formula Junior
    344
    West Texas
    I put JBL's in the footwell & replaced the stock Tweeters with ADS. Great sound at a good price, and it all appears totally stock.
    -sbf
  17. Steve Magnusson
    25,141
    #17 Steve Magnusson, Nov 29, 2009
    I did a little more research, and it depends IMO on whether you are using the stock tweeter or not, and whether or not you want the "new" speakers down below to produce only low frequencies or both low and high frequencies. On most aftermarket tweeters (or "two-way" speakers where the tweeter is built-in), the capacitor to filter out the low frequencies is part of the tweeter (i.e., if you are using the stock tweeter, use the stock filter since that is where the capacitor, C, is mounted). The inductor, L, in the "filter" will block high frequencies from reaching the new speaker so if you wanted to eliminate this you would bypass it with a jumper wire going from the 0,8 V wire to the HL speaker wire on the LH side and from the 0,8H wire to the HL speaker wire on the RH side (although this will change the overall impedance).
    Here are the schematics of the stock system:
  18. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    steve will use the stock tweeter + the new speakers come with tweeters. the sound on the new speakers is no that good. thanks for all the help. phill.
  19. KENCO
    KENCO Formula 3
    Nov 1, 2006
    2,396
    FL
    KJG
    All the speakers are not so good in a TR! Figure on doing a whole system replacement ......................or.............just listen to the glorious 12 cylinder music that comes from your rear bonnet!
  20. ria
    ria Formula Junior
    Nov 2, 2003
    732
    ohio
    phill
    yes i will live it as is for now.
