87 328 A/C tensioner pulley stud question.. | FerrariChat
Discussion in 'Technical Q&A' started by greg328, May 30, 2012.
  1. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    #1 greg328, May 30, 2012
    I'm in the middle of a bunch of updates on my car: cambelts/tensioners, new Sanden AC, fuel hose, etc..), and I'm coming up with one missing part:
    Can anybody tell me with any certainty what type of fastener the A/C tensioner pulley mounts with on the top pivot point? This is the upper hole, not the slotted one on the bottom.
    I bagged and labeled all my parts, but this one has turned up missing..
    I've got the lower small 8mm stud installed with the proper nut and washers for the slot. I just can't seem to find the correct fastener for the top pivot bolt.
    If my memory is correct, isn't that a shorter 10mm stud, held by a washer and locknut? It only sets into the cambelt cover, not through it... (?)
    If all else fails, I guess I could buy a new bolt. The stud lets you set the exact tightness though...
    Anybody know what length I would need if I get a new bolt? Pretty sure it's a 10mm fine thread...
    Thanks guys,
    Greg
    Edit: I checked the spare parts book, tav 55, but can't locate any stud. Does look like the outer fastener is a locknut with washer..
  2. JohnnyS
    JohnnyS F1 World Champ
    Oct 19, 2006
    15,284
    Illinois
    #2 JohnnyS, May 30, 2012
  3. greg328
    greg328 F1 Rookie
    Nov 17, 2003
    4,209
    Austin, TX USA
    Greg
    A ha! that's why there's a gap between the bracket and belt cover-it traps the lower AC mount bracket which I've removed because of the Sanden. gonna need to add a spacer. does look like a 10mm stud there, thanks so much...
    Greg
    Sent from my SGH-T989 using Tapatalk 2
  4. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Some of those studs are a unique size and are NLA. I hope it's not one of those.
  5. fastradio
    fastradio F1 Rookie
    Apr 26, 2006
    3,664
    New England
    David Feinberg
    Nothing special here. The stud your looking for is indeed 10x1.25mm thread pitch. Look on TAV 41 in the 308QV part6s manual. It is shown. This stud doesn't not bolt through. FWIW, using a bolt in place of a stud is a bad idea.
