News
'87 328 Expansion Valve Universal Part #??
Discussion in 'Technical Q&A' started by wonkazoo, Aug 30, 2004.
  1. wonkazoo
    wonkazoo Karting
    Aug 23, 2004
    190
    Woodside/RWC
    David
    Anyone know what Bosch or Denso part number will replace an '87 328 expansion valve??
    Many Thanks,
    dce
  3. GTO84
    GTO84 Formula Junior
    Dec 13, 2003
    562
    The TX valve is Napa# 207303. It is from a 87 Mazda 323. Externally it is just about identical. There is also a TX valve 207313 from an 80's vintage Sabb 900 that is similar but the small copper tubes from the equalizer is much longer than on the Mazda unit. The other difference is the super heat rating. The Mazda is at 5 the Saab unit is an 8.
    This is a quote from a post on a/c for 308s
  4. wonkazoo
    wonkazoo Karting
    Aug 23, 2004
    190
    Woodside/RWC
    David
    Thanks Kris. I'll get one tomorrow, have it drained yet again and do it then. It should take all of 5 minutes to replace as it is conveniently placed in the front boot. (Or is that the semi-thermal pre-heat thermoresistor for the ignition system I'm looking at??!!)
    Cheers,
    dce
  5. Mike328
    Mike328 F1 Rookie
    2,655
    Boulder, CO
    Hi guys,
    I'm also in need of a new expansion valve for my 1987 328... Very good information here. Wanted to see if anyone had additional thoughts on this? Need to jump on a part here ASAP.
    Thanks,
    --Mike
  6. dbcooper
    dbcooper Formula Junior
    Feb 7, 2005
    278
    Costa Mesa,Ca.
    Tim Romero
    Any capable auto A/C shop can match it and order it for you.
  8. wolftalk
    wolftalk Formula Junior
    Jan 27, 2004
    367
    san franciso area
    phil
    here's a generic expansion valve part number that bolts right into the system:
    208-203 / AC3851C
    $25
    replacement for:
    four seasons : 38610
    everco : A8296
