88 Mondial 3.2 ABS failure | FerrariChat
Discussion in 'Mondial' started by richkidd, Jun 30, 2006.
  1. richkidd
    richkidd Rookie
    Jun 10, 2006
    1
    Anyone had an abs failure?
    Car is new to me and everything has been great. One day the abs & brake failure lights went on and shortly thereafter the brake pressure dissappeared. I had the pump rebuilt and one of the relay's replaced and everything seemed fine. Drove for several hundred miles and also around town over the course of 3 weeks. Then again lights when on and 5 minutes later brakes gone. This time they came back in about ten minutes but later that night the lights came on again. Now when I turn the key, the pump does not turn on to charge the system and the lights never go out and the brake pressure is gone.
    I am going to check the rest of the relays again, but was wondering if you guys have had any issues with the abs pump or electronics feeding the system?
    Any ideas.
  2. danman
    danman Karting
    Mar 31, 2008
    63
    Central NJ
    So, what ended up being the issue?
