'89 air foam tube | FerrariChat
'89 air foam tube
Discussion in '308/328' started by mustardfj40, Jun 3, 2009.
  1. mustardfj40
    mustardfj40 Formula 3
    Jun 17, 2004
    1,142
    Northen California
    Ken
    #1 mustardfj40, Jun 3, 2009
    Has anyone found a OEM style or look-a-like replacement for '89 air foam tube? mine still looks ok but I don't think it will last another 10 years.
    Will this become another Unobtainium part? Thanks.
  2. Iain
    Iain F1 Rookie
    Jan 21, 2005
    3,323
    Already is. Both mine are now wrapped in black ducktape - there was nothing much left of the foam. That one you have ought to be in a museum !!
  3. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Mine did not look that good 20 years ago!
    I use some bright orange aircraft ducting. Ricambi used to have black ducting on his website, but I do not see it anymore.
  4. Futureman
    Futureman Formula 3
    May 16, 2007
    2,024
    Mine was shedding all over the engine bay when I bought the car two years ago. Kept the wire duct, but replaced it in the car with the hose from Ricambi. I figure one day I'll try and come up with an insulation solution for the wire duct.
  5. rolindsay
    rolindsay Formula 3
    Jul 14, 2006
    1,022
    Houston, TX
    Rick Lindsay
    Aircraft Spruce has air duct in metric sizes. That's what I used on my 308GTB. Looks great, as my older car used old-school ducting anyway.
  6. mustardfj40
    Jun 17, 2004
    1,142
    Northen California
    Ken
    #6 mustardfj40, Jun 4, 2009
    This foam hose is very fragile and falling apart easily. I am concerned getting this hose back in the car without poking holes in it. Anyone knows of a high temperature thin flexible rubber/vinyl, or something like Koolmat but thinner and flexible?
    Since this hose is NLA, I am thinking about in the future, I can strip the outer foam off the hose, then use a high temp insulation foam and wrap around the wired-duct core, foam thickness is about 0.5 -0.75 inch, then make a sleeve using a thin flexible high temperature fabric and wrap around the foam insulated hose and tuck the ends into the plastic collars. I would sew a velcro strap onto the sleeve to hold everything together. This hose would look puffy more like the original, it also keeps incoming air cool, and lowers the noise. But I have yet to find something like the Koolmat but thinner and more flexible: http://www.koolmat.com/race.shtml.
  7. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Mine is from Aircraft Spruce, also.
  8. judrick
    judrick Karting
    Jun 7, 2007
    64
    Knoxville,TN
    Rick Haynes
    I always wondered what my hose used to look like when new. I bought the plastic hose replacment from Ricambi.
  9. Mule
    Mule F1 Rookie
    3,758
    Alaska
    Mule
    Is Ricambi no longer selling it? I can't locate it on his site. For the original poster - find a good replacement now while you can spend the time looking. Mine turned to dust (literally) by 40K miles.
  10. AMA328
    AMA328 F1 Rookie
    Nov 12, 2002
    2,518
    ABQ-67me68-OKC :)
    well, there's always ebay. Seems someone usually has a non-original replacement up for sale.
