'89 TR fuse box, should I upgrade or not?? | FerrariChat
Discussion in 'Boxers/TR/M' started by 1TRICK6, Jul 4, 2015.
  1. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    I read a few post on Dave Helm's fuse box upgrade. Left a message for him early yesterday to get some more info but didn't get a return call. I checked a few of the white connectors in the fuse box and they all look brand new still. Will be checking the others this weekend but do I really need to upgrade?
    I'm 10 days into the ownership of a 89 TR with less than 14k miles. It was only driven 1k miles in pass 10 years.
    No service records at all, it hasn't even had the seat belt recall done yet, which I plan to do as soon the F-dealer gets the parts in.
    Any suggestions I should do or check besides looking for a place to take care of the 30k service.
    Thanks,
    Jim
  2. Turbopanzer
    Turbopanzer F1 World Champ
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    Yes.....Not unless you want to watch your investment go up in smoke. It isn't a question of if I need to but more of when. The current levels are high in a TR and it isn't wise to let it go to long.
  3. 302Tim
    302Tim Formula 3
    Jul 2, 2011
    1,182
    Northern California
    Tim
    If yours it still original it will eventually fail. The water fans, fuel pumps and A.C. motor and fan all have electric motors that become less effective over time and require more amperage to operate--the higher draw causes more heat which the fuse panel was not designed to handle. So failure is very likely. Replacing the fuse panel doesn't help the problem--you'd be better off changing all the electric motors. There are several ways to deal with this issue, the most popular being the Dave Helms upgrade. There are other options available but regardless, it's something you'd be better off addressing sooner rather than (stranded) later.
  4. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Pending getting a response from Dave Helms, do I pull the whole fuse box out? Any tips on removal. When I get the upgrade, is it simply a plug-play or will there be some soldering or extra connections involved or anything to watch out for?
  5. Melvok
    Melvok F1 World Champ
    Jul 25, 2008
    14,268
    Mel
    " I'm 10 days into the ownership of a 89 TR with less than 14k miles. It was only driven 1k miles in pass 10 years. "
    I would drive one or two years ... without any fear imo ! It has no record of many km's yet !
  6. leslie_choo
    leslie_choo Formula Junior
    Aug 5, 2012
    444
    Singapore
    BCChoo
    I have been driving my 91 Testarossa with original fuel box and the car is running well. The car is very sensitive so pls do not mess with the wiring . My suggestion is if it works don't change
  7. Steve Magnusson
    26,841
    What's the mileage on your TR? (The I^2*R heating damage at the white connectors tends to be a time cumulative issue.)
  8. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    About 30,000 Km.
  9. Steve Magnusson
    26,841
    Your honeymoon period might be nearing its end (you might want to unplug and visually inspect the four white horizontal connectors at the bottom of the fuse-relay panel -- the evidence of over-heating can't been seen when the connectors are plugged in). Hope you continue to have no problems, but that's not the typical history reported here...
  10. leslie_choo
    Aug 5, 2012
    444
    Singapore
    BCChoo
    Sure I will check... And hope it's still ok .. Thanks for the info
  11. lear60man
    lear60man Formula 3
    May 29, 2004
    1,829
    Los Angeles
    Christian
    Jim, I did the Dave Helms upgrade a few years back. Super easy process. Removal of the fuse box is: dissconnect the white connectors, a couple of bolts and maybe one or two other connectors. Its a 5 minute job. Just make sure to disconnect the battery first.
    Send it off and Dave does his thing in a day or two. Sends it back with super easy instal instructions. I took my time and it was a 1.5 hour process.
    I leave the fuse box panel door open all the time. In my mind it helps keep things cooler in there instead of trapping any heat.
    I changed mine out around 12,000 miles and there was just a hint of discoloration around the white connectors, specifically where the radiator fans get power.
  12. 1TRICK6
    1TRICK6 Karting
    Aug 28, 2014
    159
    So. Cal (L.A./O.C.)
    Jim
    Thanks for all the advice, looks like the consensus is to upgrade earlier than later, before something does happens.
    I'll check the other white connectors this week.
  13. Bradwilliams
    Bradwilliams F1 Veteran
    YES, Dave Helms will treat you right. You'll be glad you did it later
  14. Philwozza
    Philwozza Formula 3
    Apr 23, 2009
    2,045
    Winchester UK
    Phil Worrall
    I upgraded my own box. All that was needed was a little soldering and wire crimping skills.
    P
  15. 88Testarossa
    88Testarossa Formula 3
    Sep 25, 2012
    2,450
    Annapolis and Daytona Beach
    Al
    Dave did mine, quick turnaround. I believe in PM. Worth every penny for peace of mind
    Sent via itty bitty electrons
  16. sparta49
    sparta49 F1 Veteran
    Mar 3, 2001
    7,804
    LA
    Frank
    I had mine done. Worth every penny.
  17. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    It's an absolute must. Get her done. Even better to do it when your box and white connectors are in perfect condition. Do it earlier vs later.
    R
  18. tf308
    tf308 Formula 3
    Dec 14, 2003
    1,168
    Virginia Beach
    Tim
    Should you address the issue....yes
    How you go about it is your next choice. There is more than one solution depending on your level of skill.
  19. Melvok
    Jul 25, 2008
    14,268
    Mel
    Indeed ! Look at Phil's comment !
  20. Turbopanzer
    Oct 2, 2011
    11,120
    Under a bonnet
    Panzer
    With all due respect Mel........some people should not be allowed to use tools. My late father being one of them! :D
  21. UpNorth
    UpNorth Formula 3
    Sep 30, 2006
    1,769
    Quebec, Canada
    Francois
    Hey! maybe we are brothers! :D :D
  22. Melvok
    Jul 25, 2008
    14,268
    Mel
    Give that poor man a chance .... (but NOT on YOUR car .... :D )
