‘90 348- intermittent power loss. Like flipping an on/off switch. | Page 3 | FerrariChat
Discussion in '348/355' started by JOHNCJ8989, Jun 11, 2023.
  1. Qavion
    Qavion F1 World Champ
    14,651
    Ian Riddell
    #51 Qavion, Jun 16, 2023
    But switched back to two ECUs after the F355 5.2.... i.e. 360, 430, F40, F50, 575, 458, 599, 612, Enzo, California.... I think there are just too many devices (and in some cases cylinders) attached to the engine for a single ECU to handle.
    e.g. the RH ECU on a 360 has over 70 wires attached to it. You have to take into consideration all the "fly-by-wire stuff". Databusses reduced the number of wires, but Bosch/Ferrari still persisted with 2 ECUs.
    johnk... likes this.
  2. KevZep
    KevZep Formula Junior
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    One engine ECU, this is what I am talking about.
    Not talking about transmission computers and other computers on the car.
    The fly by wire stuff and the dash and so forth is all can-bus.....pretty standard stuff.
  3. Qavion
    14,651
    Ian Riddell
    Yes, that's what I was talking about, too.
    The F430 has two 121 pin Motronic ECUs... with a total of 3 times the pins on the F355 5.2 ECU. There must be a reason why Ferrari/Bosch persisted with this. Heat management? Redundancy?
    But we digress.
    KevZep likes this.
  4. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    We are getting a bit off topic, but what I am saying is there is only a need for one engine ECU, not two like Ferrari seemed to do initially when they first started down the EFI route.
    Its overly complicated for what is actually quite simple, also the whole MAF, narrow band O2 sensors and so forth, not necessary with todays tech...it was the best way back then, but certainly not now.
    Additional computers were added for transmission, ABS, climate, etc etc which is another story and not what I was talking about because they are nothing to do with the Fuel, ignition management and so forth.....
    And yes, things have become incredibly high tech now, and we will see what issues all that will throw at those cars 30 years down the track...
    Pangea likes this.
  5. m.stojanovic
    m.stojanovic F1 Rookie
    3,316
    Serbia - Niš
    Miroljub Stojanovic
    #55 m.stojanovic, Jun 16, 2023
    Just to clarify the CO potentiometer (the 383 Ohms) on the MAF. It has nothing to do with operation of the MAF as it is not connected in any way to the MAF's electronics (the CO pot is only physically inside the MAF for convenience of access). The MAF's signal sent to the ECU, representing the air mass, will be the same irrespective of the Ohms setting of the CO screw. This is because the CO potentiometer is connected between the ground and the ECU pin 43 so it trims the ECU for optimal CO. The MAF diagram below shows the connections of the CO pot - one side to the ground and the other side goes out via MAF's pin 6 (and to the ECU pin 43).
    With regard to "balancing" the CO pots at 383 Ohm, it will not actually balance the banks (the ECU-s) but it is only recommended as a starting point for balancing the two banks. The actual balancing of the banks is balancing the CO content left and right using a CO tester (exhaust gas analyser). This will most likely result in different Ohm values of the left and right CO potentiometers to compensate for small differences of the ECU-s, injector flows, FPR-s, O2 sensors etc. between the two banks.
    348Jeff, KevZep and Qavion like this.
  6. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    I haven't made a video yet but last night I swapped my "working" MAF over to a borrowed good MAF so I now have fitted 2 known working MAFS and the car ran better than it has ever done - no hesitation upon hard acceleration - it was like a different car :)
    Now that I know for 100% the cause of my problems I'm going to send my MAFS of rebuilding.
    Couple of other things I noticed that may help others is that when I checked my relays some of them were a little bit loose so need pushing down firmly to make sure they were seated properly plus one of the wires out of the back of the fuse/relay board looks like it could of been shorting on the angled metal panel above it - worth just checking for anything like that.
    What sort of solved it for me was waiting for teh car to go into "problem mode" and then do all your testing rather than trying to test it whilst its working.
    Pangea, JOHNCJ8989 and Qavion like this.
  7. Ferrarium
    Ferrarium F1 Veteran
    Sponsor Rossa Subscribed
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    The MAFs get water intrusion actually and being 30 years old they are likely a source of running issues for may cars, not sure about the OP and Lucas's issue though that sounds like a bank dropping intermittently, the issue reported is not hesitation but actual power loss momentarily. Frankly if one plans of keeping and enjoying the car's I'd have them rebuilt just for good measure, pretty sure 30 years is beyond the EOL spec for the components and they definitely will not get better with time. But that's just me.
    JOHNCJ8989 likes this.
  8. m.stojanovic
    3,316
    Serbia - Niš
    Miroljub Stojanovic
  9. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    I wonder who the seller is?! Lol ;-,)
  10. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    Turn your cars on, oop the deck, push the back of the maf or wiggle the maf wire? Does it change idle, that could be your issue.
    Sent from my SM-G990U using FerrariChat.com mobile app
  11. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    Apologies for the double post - I get mixed up about which thread is which but have just tried the above test with 2 good mafs and the connecters seem good.
    Connector Test:
    Running with 2 good known MAFS - as you can see you can disconnect either side one at a time and although the car stumbles it won't stall. I've also been driving it this morning and it's running great.
    I've just posted off 2 faulty MAFS to FIC so I'll let you know how I get on.
    I'll also try this eBay one when it arrives in a week or 2 so we can see whether they are any good or not.
    Qavion likes this.
  12. JOHNCJ8989
    JOHNCJ8989 Formula Junior
    Dec 11, 2003
    521
    Thanks for the info. I ordered new TPSensors that will arrive today. I’ll see if those make a difference, and if not I’ll go down the MAF route.
  13. Pangea
    Pangea Formula Junior
    Mar 27, 2011
    442
    Nick
    I agree with your thoughts...I nearly went down the Motec route a few years ago. If it was more plug and play I might have been more enthusiastic. To much of a purist.. I know the performance / drivability would probably been better overall having worked with Motec for years. Mainly race cars though. I accept its out of date but I can live with a few minor issues now and again. In twelve years Ive not had anything that couldnt be fixed easily including an ECU fail. Life with an older Ferrari eh. Would still be interested in the results of your venture if you go ahead . Hopefully it would be a positive experience for you...
  14. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
    I'm betting maf.or wiring still, check the wam for installing/setting the tps correctly, There is a tps setting post from Ernie out here as well.
  15. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    Those tempted by a standalone ecu may find this interesting - not a 348 obviously
  16. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    That's where I got to as well, I thought there wasn't really enough of an issue with mine to justify doing an ECU swap. My car ran well on the dyno, WOT is great, the parts which aren't that great are lean cruise, idle during warm up, hot idle, hot start, and the odd instance where one bank just cuts out for a short time, all the usual issues you see people having. All this largely due to ageing components in a system which is so convoluted because that was just the way it was back then.
    Since I can do the ECU swap myself, it makes sense to make it happen.
    Im not a fan of Motech, I have been using Link ECU's since about 1992 so its what I know and easy for me to do.....
    I'm not doing it for more horsepower, but going to just fine tune it for the octane fuel I use and for drive-ability.
    Changing ECU's is not really a DIY thing, you need to know what you're doing, you need a dyno, and the time to do it.......Luckily I have all these things.
  17. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    The MAF's wont make the engine cut out if they lose contact with the ECU. It will change it's idle and lean cruise, but wont make it cut out.
    The ECU uses pre determined tables and TPS so that it wont cut out.
  18. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    If you have to pay someone to do it, then I would not recommend it, not economically viable IMO, but you DO need to know what you're doing.
    The guy in the video is onto it, the LINK ECU are very user friendly. Also a New Zealand company my friends business has been dealing with for nearly 30 years....
  19. JOHNCJ8989
    Dec 11, 2003
    521
    So I replaced the TPS on both sides and it did the same thing after a short drive. While it was acting up and idling rough I disconnected the left MAF and it stuttered badly. When I disconnected the right side the idle improved dramatically. Took it for a long drive with the right side MAF pulled and it drove perfectly. Must be that MAF going bad because the connectors look good. I didn’t realize it would run with one disconnected. Does the ECU just default to a predetermined setting?
  20. 348Jeff
    348Jeff Formula 3
    Oct 25, 2011
    1,554
    Jeff
    Why dont you swap the mafs round and see if the fault moves then you can confirm its the maf?
  21. Qavion
    14,651
    Ian Riddell
  22. KevZep
    Feb 17, 2020
    568
    New Zealand
    Kevin Bennett
    Yes, it reverts to using the per-deterimined fuel map inside the ECU rather than runtime values with the MAF and O2 sensors and so forth.
    It wont make the engine cut out or lose power, but it could make it run rough if there are other associated issues.
  23. JOHNCJ8989
    Dec 11, 2003
    521
    I’ll for sure do that..
  24. Ferrarium
    Jul 28, 2018
    5,728
    Central NJ
    Eric
  25. JOHNCJ8989
    Dec 11, 2003
    521
    There are no cel. I thought I might swap sides to see if it’s the MAF itself or if it’s wiring related on that side ..
