'90 348 TS Alternator Issue | FerrariChat
Discussion in '348/355' started by Oakmontgolf, Aug 14, 2010.
  1. Oakmontgolf
    Oakmontgolf Karting
    Jun 27, 2010
    72
    Frisco, TX
    Dave
    Hope someone here can help or has an idea. Took the car to the ferrari dealership after the battery light came on...said alternator needed to be rebuilt so they sent it to someone locally who does that, got it back and drove the car less then 3 days before the light came back on again. Went to dealer they sent it back to the guy who rebuilt it he said voltage regulator needed to be fixed/replaced (cant recall). Had engine out service done during all this...today I pickup the car and within 1/2 mile from the dealership I hear a high pitch noise and within the next mile it subsides to low whistle. Go back to the dealer and left the car running they come out and test drive it...no noise. We pull back into the dealership and the battery light comes back on again. I assume the noise I heard is tied into the alternator, maybe? Any idea why the alternator keeps having issues...the dealership is at a loss as of this moment.
  2. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    Sorry, but at this point it could be just about anything. The most important thing (to me) would be to make absolutely certain that the noise ISN'T coming from the timing belt, or from its tensioners.
    There is no reason why the alternator shop should not have been able to repair your alternator so that it would last for at least a couple of years. If your car is a 1990, it probably has the Delco alternator, easy to overhaul. It may have been retrofit with the Nippondenso alternator.
    As an aside, perhaps this is an indication of why a dealership would not want to remove and rebuild an alternator, as opposed to replacing it. Remember the "raccoon" 348 incident? The dealer insisted that they would only replace the alternator, which required upgrading the car to the Nippondenso unit, available only as a kit with new alternator, belt, bracket, and harness, at a cost of about $5000. The problem on that one turned out to be in the harness in the first place, so the whole issue was a fiasco for the owner. The dealer doesn't want to see comebacks.
  3. plugzit
    plugzit F1 Veteran
    7,792
    Redondo Beach, CA
    Bruce Bogart
    I remember the raccoon incident quite well. It set me to wondering...to cook a raccoon of say 20lbs, how long would you leave it on the manifold at 3000rpm? Does it need to be turned?
  4. Oakmontgolf
    Oakmontgolf Karting
    Jun 27, 2010
    72
    Frisco, TX
    Dave
    miltonian,
    Appreciate the insight...dealership did say it was the ac delco not the newer replacement. Dealership is taking it off today and will send it back to the guy who rebuilt it Monday. If you think of anything else that maybe a cause...appreciate it otherwise let you know what the report is next week after he looks at it.
  5. Miltonian
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
    As far as other possibilities for the source of your noise, we have seen a few instances of cracked alternator brackets that allow the belt to come loose. And of course, if the locking bolt isn't tightened after adjusting the belt tension, it WILL back off and loosen the belt.
    It shouldn't be hard to diagnose the source of the noise, but there may be more than one problem (a belt problem causing the noise, and an electrical problem causing the light to come on).
  6. Saint Bastage
    Saint Bastage F1 Rookie
    Jun 1, 2007
    2,548
    Connecticut
    Lane
    #6 Saint Bastage, Aug 15, 2010
    15 minutes then 5 minutes per pound. No need to turn it but your gonna need some seasoning. Recommend a garlic blended onion salt and tarragon.
    Seriously though...The VR is a $10 part (through channels other than Ferrari) that should have been replaced during the initial rebuild. I know why the dealer is at a loss, something doesn't smell right. Was the battery tested...perhaps a ground across cells or a direct short someplace on the car? (just a guess)
  7. Oakmontgolf
    Oakmontgolf Karting
    Jun 27, 2010
    72
    Frisco, TX
    Dave
    New Interstate battery 10/09, dealer checked and not the problem.
  8. 3forty8
    3forty8 F1 Rookie
    Apr 25, 2006
    2,713
    San Diego
    Eric
    I've had my alternator rebuilt and fail within 48 hours because of diodes going bad on the bridge rectifier. Make sure the guy who is rebuilding it is using heavy duty components and to test the darn thing before they install it again.
    As for the noise, belt not tightened properly? Bracket cracked? Bearing starting to get spun on the back of the alternator? It could be many things.
  9. redzone
    redzone Formula 3
    Mar 31, 2007
    1,218
    Beach
    I rebuilt mine myself using parts taken from a thread here 15k ago & its been fine.The lite was coming on at high RPMS.Try it out,sometimes you have to do it yourself )
  10. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    Since you have the Delco alternator, and your car is a '90, I'm assuming your battery is located in the left rear of the engine bay? If it is, have you checked the bullet connectors under the airbox? Those have a tendency to loose their "grip" and don't maintain good contact = battery light comes on. So have a look at those and then get back to us.
    As for your "whistling sound" check all of vacuum lines on the plenum. Make sure they are all hooked up, and in good shape. No cracks or splits.
  11. ernie
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    LOL!!!
  12. Zanny1
    Zanny1 Formula 3
    1,160
    Arizona
    Good advice. Better yet, take the factory cable out. Buy a new 5' cable. Cut the connections off the old one, slip off the factory plastic insulator-cover, slide it over your new one, heat shrink a couple of pieces on each end, and put it back in. Looks original, takes about 2 hours (I work pretty slow) and forget about the bullet connector.
