90 Testarossa - Changing brake vacuum hose from servo to engine bay | FerrariChat
Discussion in 'Boxers/TR/M' started by Paul Colville-Nash, Jan 3, 2025.
  1. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Hi All, happy new year to everyone!
    1990 Testarossa - engine out, major engine bay overhaul, new radiators etc so taking the opportunity. As part of replacing all the rubber hoses, most of which are straightforward, but the vacuum hose from the brake servo to the engine bay union is putting up a fight! It’s brittle and cracked in the engine bay section - could cut it back but would rather replace. I take it that it is threaded through a metal pipe from within the front scuttle just below the windscreen down behind the front wing and into the sill space. Having pulled quite hard(ish - could put more force on it I guess) from both ends, it’s not budging. Given our wonderful uk climate I’m wondering if rusted inside the tube though my sills look in great condition from a fibreoptic inspection - can’t see any rust. I’ve seen from other threads the braided outer coverings can be our enemies though. If anyone has changed this hose, advice please! Is it better to pull from the front or back, is it worthwhile trying to get some GT40 oil down the tube, any other tricks? Worst case could be wing off and cut into the tube but rather not…thanks for any help gratefully received! Paul
  2. EDoug
    EDoug Formula Junior
    Apr 19, 2005
    266
    Southern Florida
    Paul, I did this not long ago on my 1986 Testarossa. The following is what helped me understand where the hang-ups for the vacuum hose were. I found a couple pics from I think Rattarossa (?). I don't know if you are correct about the hose being threaded through a metal pipe. I assumed it was just routed through the rocker area. In any case, look closely at the following front left fender teardown pics from Rattarossa's rebuild. You will see two 90 degree turns that the vacuum hose makes, one being into the fender access opening at the booster and straight down about two feet, and the second being a 90 degree turn into the rocker. The second pic shows the vacuum hose at the booster heading to the first 90 degree turn. I pulled the old hose with the new spliced on hose from the engine compartment at the radiator during my engine out. A few more pics and suggestions follow. Hope this helps. EDoug
    Cut down a 1/2 inch x 1/2 inch barb hose splicer to keep it short to make the 90 degree turn at the rocker, and splice the new hose onto the old hose in the front at the booster.
    Push the hose straight into fender opening at the booster to try and give a little slack onto the old hose at the 90 degree turns. Pull a little on the hose at the rear and try alternating feeding in from the front opening to keep a little slack going and then pulling a little. Be a little gentle until you know the splicer has cleared to second 90 degree turn. I think I did a little back and forth and then it was clear.
    Spliced on new hose pulled out with the old hose.
    Make sure your new hose is DOT 15/32.
  3. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Thanks EDoug. Mmmmh - maybe I’m wrong about that metal tube then though my car a bit later. Couldn’t see anything like that ratarossa picture from a fibreoptic through the wing repeater indicator. At the scuttle, hose seems to go through a flared metal fitting down into the wing and looks similar through the front of the sill when putting a fibreoptic through the rubber bung in the front wheel arch which lets you see into the sill from the front and again seems a flared metal fitting from tapping with a screwdriver. I presumed then they were joined but maybe not! Used that joiner method for the other pipes through the central tunnel. Have tried to both push and pull, doesn’t seem to want to move at all but sounds like perseverance name of the game! Noted re the hose and making sure right size and vacuum rated - too many supposedly vacuum hoses aren’t! Got mine from Summit Racing in the US - couldn’t easily find a UK supplier. When I get back to the car, I’ll take some photos but anyone with a newer car who can shed light on any design changes to the routing through the front wing space?
  4. EDoug
    Apr 19, 2005
    266
    Southern Florida
    Paul, my '86 hose is one piece front to back until it gets to the manifold and tees off. Only saying that this is what worked for me and yes it took a little persistence. EDoug
  5. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Thanks EDoug. Yes agree, I’m pretty sure my hose single piece as yours and that tube simply a “guide” that hose passes through, I’d guess to make this replacement easier if needed though I’m not sure that necessarily figures in a Ferrari designers mind! The parts book says single piece hose but interestingly doesn’t show this tube in any of the body/coachwork diagrammes if indeed there even is one. I’m going to “phone a friend” and have another crack using your approach with some additional moral support :)
  6. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
  7. EDoug
    Apr 19, 2005
    266
    Southern Florida
    Paul, I can't speak to any routing hardware changes that might have occurred on later Testarossa's, but your pics seem to show a pretty tight interference to pull through. Others on this site should be able to comment on any other needed techniques for later TRs. EDoug
    The Ratarossa rebuild project front wheel well pics I copied were from post # 259 on page 11. (The project car is an 86/87 stated in post # 27 on page 2.)
    'The Ratarossa': The Testarossa Spider Rebuild Project
    Discussion in 'Boxers/TR/M' started by spiderscott, Sep 15, 2015.
  8. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Thanks EDoug; the Ratarossa project is something special!
  9. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Image Unavailable, Please Login Well, definitely very tight. Finally managed to move it with a chain hoist but even now can’t shift it by hand push/pull. Next to replicate your joiner EDoug and cross my fingers. Bit of silicone lube I am thinking…
  10. Paul Colville-Nash
    May 18, 2018
    23
    London
    Paul Colville-Nash
    Well, tried the double hose barb and couldn’t get it round that bottom bend into the sill, kept stripping out the inner rubber of the hose and parting. Not helped by how tight these hoses are in that guide tube. But, made up a pull through using a boat shift cable and trapping a short barbed metal plug in the end of the hose - that pulled through nicely! Should anyone in the UK want some vacuum hose, I have a lot left as I had to buy a 50ft coil (!) so enough for another RHD Testarossa etc. DM me.
