90 TR Fuel Stabilzer ? | FerrariChat
Discussion in 'Boxers/TR/M' started by Mr.Chairman, Nov 18, 2008.
  1. Mr.Chairman
    Mr.Chairman F1 Rookie
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    Greetings all... Just a quick question. I normally drive mt car in the winter but not as much. I think its a good idea to add Stabil to the fuel. My questions is: Is this a good idea? What would be the mixture (how much to add)? Should I worry about this if my car sits 2 to 3 weeks without being driven? Some input would be greatly appreciated.
    Robbie
  2. carguy
    carguy F1 Rookie
    Oct 30, 2002
    3,425
    Alabama (was Mich.)
    Jeff
    The ratio of Stabile to Gas is mentioned on the container somewhere. If your car is going to sit for a few months I would probably add some. If the car is going to sit for only a few weeks then Stabile will probably not be necessary. The bottom line is, how long will the fuel that's in the tanks right now be in there before some fresh gas is added? If it's going to be months before you hit the gas station again...yes...add some Stabile. It will give you piece of mind.
  3. Mr.Chairman
    Mar 21, 2008
    2,987
    New Jersey
    Robbie
    I was thinking of adding stabil.. fillthe tank then I am o.k. for the winter. Chances are I will probably fill up once over the winter - depending on snow.
  4. blown daytona
    blown daytona Formula 3
    Feb 6, 2008
    1,679
    maryland
    Ive had cars & boats sit for months at a time without adding anything and it is never an issue. I guess it wouldnt hurt to add a stabilizer for long term storage. I once had a car in storage for several years, never added anything (because I always said Ill get around to it). To my suprise, after I put a fresh battery in it, it started right up and ran fine. Believe me, I was ready for some big problems and dont recommend doing this by any means.
  5. Radnor
    Radnor Formula Junior
    Jul 16, 2007
    656
    I haven't added stabilizer to by boxer which I don't drive much, if at all, during the winter and have had no problems. However, I recently had my '72 MGB restored and the folks who did that recommended either using stabilizer or putting in race fuel over the winter. So, this year I am using stabilizer on all my "hibernating" cars. 1 oz treats 2.5 gallons.
  6. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    Def add it at the above noted ratio (1oz/2.5gal), but do not go higher than this! It could gum things up as I learned the hard way many moons ago when stabilizing a motorcycle. Figured if 1oz/2.5G is good, more must be better! I was wrong.
  7. Spasso
    Spasso F1 World Champ
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    #7 Spasso, Nov 19, 2008
    I have my TR put away for most of the winter so I can attend to maintenance items and don't expect to be adding any fresh gas to it until next spring. It will be started and run on occasion but not really used. I recommend adding the stabilizer AND a gas "drier"/cleaner to the the system, run the engine until fully warmed up so everything gets recirculated throughout the system.
    According to my owner's manual the TR with reserve holds about 30 gallons, 26.5 + 4 ga. reserve.
    Per recommended ratios on the Sta-bil bottle I added close to the entire bottle (large).
    I use this stuff in my home generator as well, nothing like trying to start a balky generator in a wind storm.
  8. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I'm not sure why your motorcycle got gummed up, the reason for adding the Sta-bil is to PREVENT the deterioration of the fuel and the resulting varnish and "gumming" problems. Maybe your bike had a "pre-existing" condition and the Sta-bil aggravated it.
  9. ducowti
    ducowti Formula 3
    Jan 27, 2008
    1,557
    NY/SC
    David
    Me neither. I actually don't think it got gummed up, I just used the wrong word quickly typing. But based on past experience including w.that very bike, too much Stabil caused some real PITA starting problems.
  10. Spasso
    Feb 16, 2003
    14,656
    The fabulous PNW
    Han Solo
    I imagine the smaller volume of your tank might allow you to change the overall chemical balance of your fuel to a higher percent hence the hard starting. Makes sense.
