91 348TB - Radiator Overflow | FerrariChat
Discussion in 'Technical Q&A' started by ccantrell, Sep 10, 2005.
  1. ccantrell
    ccantrell Karting
    Feb 23, 2004
    86
    Crossville, IL
    Chris Cantrell
    Hi,
    I have drivin ~700 miles on my 91 348TB in the last month. Today, for the first time I noticed a small puddle of green antifreeze that seems to be coming from the tube that run down to the bottom of the car on the passenger side under the engine area. I am not sure if it was there for a while but I did let me car warm up for about 15 minutes before driving it this morning. I noticed it when I returned.
    Is this something to be concerned about? I was thinking the cap spring (which I understand keeps pressure on the system) might be weak and causing it. Any thoughts or reasons to be alarmed?
    Thanks!
    -chris
  2. PassionIsFerrari
    PassionIsFerrari Formula 3
    Aug 15, 2004
    2,454
    Have you double checked to make sure it isn't coming out of the cap somewhere?
    Also...there is a rubber hose with clamps on 2 sides that connects the coolant tank to the metal piping that runs along side the rear of the engine bay..
    Can you run the car and see where it is spitting from...Make sure not to overheat it though!
  3. ccantrell
    ccantrell Karting
    Feb 23, 2004
    86
    Crossville, IL
    Chris Cantrell
    Doesnt seem to be overheating. Drove it a lot today and everything seemed normal. Yes, it is coming from the tube you described because when I looked, there was a small amount on the bottom of it.
  4. No Doubt
    May 21, 2005
    72,740
    Vegas+Alabama
    Mr. Sideways
    That sounds like normal overflow.
    if it's just a few drips after a hot run, then all is by design and fine.
  5. ccantrell
    ccantrell Karting
    Feb 23, 2004
    86
    Crossville, IL
    Chris Cantrell
    Thanks! That is what I thought but hey, never hurts to check with the experts!
  6. rivee
    rivee F1 Rookie
    Jan 20, 2002
    3,731
    Nowhere important, USA
    You might also want to check your rad cap. Sometimes the spring gets old and won't hold the coolent pressure like it's supposed to.
  7. ccantrell
    ccantrell Karting
    Feb 23, 2004
    86
    Crossville, IL
    Chris Cantrell
    I was thinking about replacing that anyway. 15 year old part, probably wouldn't hurt to replace.
    Thanks!
    -chris
  8. Miltonian
    Miltonian F1 Veteran
    Dec 11, 2002
    5,966
    Milton, Wash.
    Jeff B.
  9. f355spider
    f355spider F1 World Champ
    18,055
    You may have simply overfilled it in the past, and getting it good and hot it is finding it's natural "equalibrium", by spitting out the excess. When cold, you might want to confirm it is at the proper level (which I am unfamiliar with on the 348).
  10. Ricambi America
    Sponsor Owner
  11. ccantrell
    ccantrell Karting
    Feb 23, 2004
    86
    Crossville, IL
    Chris Cantrell
    Anyone vouch for these guys ;)
    I will be placing an order later tonight!
    BR,
    -chris
  12. hank sound
    hank sound F1 Veteran
    Jan 31, 2004
    5,953
    Burbank, CA
    Hank Garfield
    Without a moment's hesitation!!!
  13. ernie
    ernie Two Time F1 World Champ
    Nov 19, 2001
    22,620
    The Brickyard
    The Bad Guy
    You will also want to make sure that all the air is bled out of the cooling system. If there is air in the system it will cause the coolant to get hot, and that may be why there is some coolant coming out of the over flow. When you bleed it make sure that you have the heater on, and set to the hottest setting. The bleed screws are on the radiator feed pipes that run across the back of the fire wall. The two screws will be on the right hand side.
  14. 88MONDIAL
    88MONDIAL Formula 3
    Apr 13, 2005
    1,052
    Racine, Wisconsin
    Jim Smith
    I had that problem in my 3.2 Mondial, a little green antifreeze dripping. Went to the parts store and got a new cap, fixed it right up. I was told by a Ferrari Dealer to say I have (can't remember what car) instead. It used the same cap. $5.25 later the leak was gone. Nothing to worry about.
