91 Testarossa Dash lights flickering | FerrariChat
Discussion in 'Boxers/TR/M' started by PineChris, Apr 19, 2021.
  1. PineChris
    PineChris Formula 3
    Apr 17, 2013
    1,082
    California
    Chris
    Anyone experience this? When driving at night the other day I noticed my dash lights, including the ones in the center console would flicker. The gauges all work, just the lights would change from bright to dim, even occasionally go out for a split second.
  2. V4NG0
    V4NG0 Formula Junior
    Dec 14, 2018
    705
    Charles Edward Cheese
    Rheostat. It’s a common problem. (I just went through this issue.).
    Either replace yours or have it rebuilt.
  3. Steve Magnusson
    26,846
    +1 -- Just give the dimming rheostat knob a few spins back and forth to "wipe" it as a first fix attempt.
  4. V4NG0
    Dec 14, 2018
    705
    Steve’s solution is much cheaper. Definitely try that first.
  5. PineChris
    PineChris Formula 3
    Apr 17, 2013
    1,082
    California
    Chris
    Thank you!
  6. Steve Magnusson
    26,846
    Please let us know if you do need to replace it, or if it was just (another ;)) case of extended disuse.
    PineChris and turbo-joe like this.
  7. Lieven Engelbeen
    Jun 12, 2018
    127
    Belgium
    Silverballgames
    May I ask where to find this dimming rheostat in the car ?
  8. Steve Magnusson
    26,846
    On the later TR, it's the knob in the tachometer. See "Instruments and controls" in Section 1 of your TR OM.
    Lieven Engelbeen likes this.
  9. V4NG0
    Dec 14, 2018
    705
    In early TRs, it’s in the center tunnel down low near the odometer and digital clock.
  10. ago car nut
    ago car nut F1 Veteran
    5,506
    Madison Ohio
    David A.
    If you remove the instrument cluster, you can clean the copper pad in the rheostat with a pencil eraser.
    PineChris likes this.
